Question about KitchenAid Washing Machines
My Kitchen Aid Top Loader the middle plastic thing that turns the cloths is not turning but the base is. Seems like it is off track what do I do
    Sergeant:
  • 239 Answers
Sounds like you need dog kit WHI 80040
Posted on Oct 24, 2010
6ya staff
SOURCE:
I have a kitchen aid food processor kfpm775, I have had endless problems. I have a new bowl and lid,it worked once.It has been assembled properly and done the check on the motor, which seems fine.
To work properly the bowl needs to first be in the correct place, on model 770 which we have here it is handle in the middle at the front. Then the lid goes on, it's obvious which way is correct with that part and then the pusher must be in the tube to activate the safety cut off switch. It is very rarely the cutoff switch itself which is inside the motor housing. If you look at the motor unit without the bowl on you can see right in the middle up by the top of the housing a hole with white plastic inside it. That's the safety switch that all the levers in the bowl & lid activate. If you turn the unit on (no bowl) and push the run switch down then activate that safety switch be depressing it in with something plastic the motor should run. That will prove to you at least that it's not the motor. That model is close to end of life now, bowls & lids are scarce and the general purpose blade is finished.
Nov 27, 2017 | Food Processors
Base of Door on Kitchen aid Side by Side. we replaced cam but door still falls off from top when we open. Can see this door sits lower the freezer side
Well Tell that Door to stop that! Imagine the nerve!
Oh what you need is the whole door replaced and the guides/cam replaced too! A little secret, somewhere you have lost or it did not come with it installed a part to that door. Call Kitchen Aid. They will Most certainly help you. Get your product I.D. number before.
1 (800) 422-1230
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Sep 30, 2015 | Refrigerators
My kitchen aid stand mixer startnig making noise and wobbling. I noticed that the pin attaching the top to the base has been pushed out halfway and I can't push it back. Any solutions?
Remove the bowl, turn it upside down on a towel, look up inside the pedestal. Right in the middle where the hinge pin goes through there is a screw, unscrew it a little, push the hinge pin back to where it belongs and then tighten the screw up tight. Turn mixer up the right way, raise head up, fit bowl & flat paddle. Lower head & turn machine on low, listen for paddle tinging on bowl, if it is touching turn off and raise the head. Look into hinge area from the front, that screw is the head height adjustment. Clockwise to lower paddle in bowl, anti clockwise to raise. You want to lower it until you hear the paddle tinging on the bowl & then raise it enough to clear without tinging. You don't wind the screw in & out huge amounts, 1/4 to 1/2 a turn at a time is plenty.
Dec 14, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
How to separate coupler
Assemble it with motor secure and base & feet on. Drill 3 or 4mm hole in edge of coupling Put screwdriver into hole on a large angle and whack the handle to undo the coupling. You are whacking it to turn in the same direction it turns when the motor is running.
Nov 20, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
My Kitchen Aid clothes washer is leaking water from the bottom.
HI couple things to check, water hoses coming into washer, tip the washer back and look underneath and see if you can see where its coming from, most common leak on this one is the drain pump which is located right on the front of the motor, if you tip the washer back its a plastic pump with 2 big hoses going into it, they usually crack and leak water from there. They are only about $30.00 to buy.
Sean
Mar 29, 2011 | KitchenAid KAWS850L Top Load Washer
The middle and top spray bar does not seem to
Is there enough water getting into machine. I it fills until the float shuts off water valve the the pump or motor may be bad.
Jul 10, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
My magic bullet won't press down. It stays stuck and I cannot get the cup to push down onto the turning mechanism that is totally intact. It seems the side 3 pieces will not move downward when the cup is...
Had the same problem - it wouldn't press down. The little white plastic things inside of the base that go up and down when the cup is pushed down, were stuck. I think that something leaked into them so they wouldn't slide easily. I wiped out the inside of the base with a damp cloth and then I put a drop or two of WD40 at the top of the white plastic pieces and rubbed it up and down the length of all 3 of the white plastic pieces (this being done with the base lying on its side so the WD40 doesn't drip down into the mechanism). Then, with base upright, I used a screwdriver to try to manually push the white plastic pieces down. It worked. Of course before doing any of this - be sure the thing is unplugged (duh!).
Mar 18, 2010 | As Seen On TV Magic Bullet Food Processor
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 24, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
My kitchen aid superba won't spin until i take wet clothes out close the lid again so that it begins to spin while empty, and then return clothes and it will usually spin then, unless a heavy load, then i...
I think that you have a bad drive block. It is located under the inner tub and the agitator. It is a pretty intense repair if you have never replaced one.
Feb 28, 2009 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
24 people viewed this question
Top KitchenAid Washing Machines Experts
gbob59
Eric Taylor
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
