Question about Kenmore 24032\24036 Top Load Washer
Intermittent agitator - Kenmore 24032\24036 Top Load Washer
  • Kenmore Master
  • 8,220 Answers
Your dogs (part #80040) are worn out. intermittent agitator - ac0b389.jpgThose ridges wear smooth with age. That causes them to skip or slip. The clothes don't get washed correctly Remove the agitator and sit it on the floor. Hold down the base with your feet and yank the upper portion off. Replace them dogs and party on. I have prepared a video and service manual here:
How it works: Direct Drive washer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 24, 2010
  • CD Chancey Nov 13, 2010
    Sometimes the top won't just pull off, you have to scrape away 4 areas of melted looking plastic that hold the top on, otherwise all is the same....
SOURCE:
The agitator is only working in one direction so the washing is getting tangled
The top portion of the wash tub agitator is designed to rotate in the clockwise direction. It should be intermittent. Turn stop turn stop ....in its normal operation.
There is a set of plastic cams that allow for this function. Below the top agitator the lower agitator goes back and forth. With a short load the water just reaches the upper agitator. Try short load. Other possibility the tub is under filled try increasing the water level.
26221857-hkbf5riehselkv40qtw2in2z-5-2.jpg Two piece agitator
26221857-hkbf5riehselkv40qtw2in2z-5-5.jpg Two piece agitator.
Hope this helps?
Jun 20, 2016 | Washing Machines
What part # for agitator dogs?
The parts number you seek is 80040 they should run about 5 bucks or so.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 20, 2015 | Kenmore Washing Machines
Sped Queen motor overload
It's 20 years old and you want to repair it?
Mar 19, 2014 | Speed Queen Washing Machines
Washer makes clicking sound while agitating
you should replace the control panel or get a new washer.
Mar 01, 2014 | Whirlpool Washing Machines
Noisy when agitating
sounds like a bad transmission
Jan 27, 2014 | Speed Queen AWS44NW Top Load Washer
Kenmore 80 model 110.25842400 agitator moves intermittently like it is missing a gear or something
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Mar 12, 2011 | Washing Machines
The agitator arm is intermittent on my ultimate care II
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 07, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't advance thru cycles, very weak agitation
its seems to have serious transmission problems, hence the rebuilt replacment offer. if the timer has quit also, probably most economical thing to do is get new machine, as these repairs will excede the cost of new unit
Sep 02, 2009 | Washing Machines
The agitator works intermittently
Replace the agitator dogs (4 small white/beige plastic parts) inside the agitator, they are worn.
The part number is 80040.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator
Faultly agitator spline or gear box fault. Regards Advisor
Aug 22, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
60 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
