The machine won't drain and stops after wash cycle.
  • 478 Answers
Sounds like a broken lid switch. You can locate this by looking around the lid and the lip, if I knew which machine it was I could instruct you to by pass it. If it is a whirlpool or roper it can be jumped under the control panel at the plug on the lid switch side by splicing the gray wires together, ignore the green.
Posted on Oct 24, 2010
SOURCE:
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Washer won't drain!
Sounds as the pump has gone wrong, if it's turning & doing the usual cycle except for draining the motor is fine, check the pump filter trap to be sure there is no obstructions as a simple penny can stop the pump motor turning preventing the machine from draining, I hope this helps.
Jan 24, 2018 | GE Spacemaker WSLP1100D Top Load Washer
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
My washing machine won't finish its cycle?
try the reset again but turn the water off
Feb 25, 2012 | Zanussi Washing Machines
Washing machine won't drain. nothing apperars to be blocking it.
if the machine is stopping the cycle when the draining sequence is following ..it means that the evacuation pump is blocked...and you need to open the pump lid and see if anything is blocking the "propeller"....if this isn't the case..it means that the pump 's motor is dead ..and you need to change it ...(in case the other cycles works and it stops just when it gets to the draining ....otherwise ..it may be a software issue ..and you will have to change the main board..)
Jul 05, 2011 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
