Question about Pentax Optio 33WR Digital Camera
I have an optio33wr digital camer. The memory card accidentally got locked. How do I unlock it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on May 12, 2011
SOURCE:
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
My samsung s630 digital cameral is stuck on card lock how to i fix this
It's not the camera, it's the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 13, 2011 | Samsung S630 Digital Camera
When i turn on my camers it says memory card locked
Hi there, Some memory cards have a very little (like a button) type of plastic on one side of the card, which can move (slides across). At one position its locked & at the other its unlocked.
Hope this helps. ****.
Nov 26, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
When i place a memory card in the camera it says memory card is unusable please insert new memory card i have already tried 2 cards
just first check that there is nothing else in the card slot. Tiny things can accidentally find there way in. Using a vacuum cleaner try to clean anything out.
If this does not work ask again and give the brand and model number of the camers.
Jun 20, 2010 | Kodak EasyShare P850 Digital Camera
Just installed memory card and gives me lockecke camer msg and cannot take any pictures
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 15, 2010 | HP Photosmart E317 Digital Camera
Memory card lockes on my panasonic lumix
If you take the card out of the camera, there's usually a tiny little switch on the card itself.  You can lock the card so you don't accidentally write over important photos.  Because it's so tiny, it's easy to switch it accidentally...and some are loose so they switch over on their own.
Mar 16, 2010 | Panasonic Lumix DMC-FZ18K Digital Camera
How do you unlock a 1gb sandisk mommory card for mobile
The side of your SanDisk SD Card has switch to lock or unlock the card. This prevents accidental data deletion. If the lock is broken, no other means but to replace the card or buy a new one.
Jun 06, 2009 | Kingston 1GB Secure Digital Memory Card
CARD LOCKED
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Lee
Apr 26, 2009 | Pentax *ist D Digital Camera
Card locked
>look for a lock tab at the side of it
>push it up
>insert the memory card back.
>that should do it
*card lock is a feature of the memory card so that you won't accidentally erase the files that are saved in it
hope this helps
Feb 20, 2009 | Samsung L200 Digital Camera
Lumix dmc fs3 troubleshooting - memory card is locked
Take the card out - on the side there is a little white slider with a locked & unlocked padlock symbol - move it to the opposite position it is in now.
Nov 06, 2008 | Panasonic Lumix® DMC-FS3 Digital Camera
Pentax Optio 33WR Digital Camera Logo
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
