Question about MotorGuide Tour Series Freshwater Bow Mount 109lbs Thrust 36 Volts 50" Shaft 21 Mount
Need step by step instructions on how to change the trolling motor steering cables pro digital 82 lb
SOURCE:
protek480
  • 1730 Answers
SOURCE: Footswitch for 1988 41 lb thrust Model Brute
you can get one @ www.grainger.com
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 04, 2009
SOURCE: Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Posted on Jul 24, 2009
SOURCE: MotorGuide pro series 46 lb.thrust not turning smooth
Check the beaing locted where the inner shaft passes thru the outer tubing below top of motor
Posted on Sep 08, 2009
  • 5 Answers
SOURCE: i have a 37 lb thrust motor guide stealth 5forward
trolling motor parts.com
Posted on Apr 30, 2010
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
Good battery , good battery in remote 70 lb thrust trolling motor - no go. ?
Hey Rob,, ??? ..Did you have the batteries CCA checked?? Cold Cranking Amps..?.. this is the only check to determine if your batteries are actually "good"...Next, take a volt meter and check the voltage at the trolling motor connection..if you have voltage at the plug, its time to move up to the head of the trolling motor...Since I do not know what brand if trolling motor we are working on.. these guys will take care of you from here...
home
Jul 09, 2017 | Boating
The first thing to check,(After making SURE the electricity is disconnected to the trolling-motor) remove the propeller and see if the shear-pin (Usually made of brass) in in place and not sheared/broken.
If it is, your local marine shop should be able to provide a new one. I always carry spares. If the pin is OK, the windings may have an electrical fault that would require a factory-repair.
Sep 05, 2014 | MotorGuide Transom Mount Great White...
How should a 12 volt deep cycle battery last when trolling on #1 with a 30 lb thrust
It depends on the Amp/Hour rating of the battery and the amount of current your motor draws on setting 1.
Apr 17, 2012 | Minn Kota Endura 30 Freshwater Transom...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
I cant download the manual. is there a manual on website
Is there a manual I can download for a MKAC (2002) 40 lb. All-Terrain bow mount trolling motor?
Jan 07, 2010 | Vivitar ViviCam 8025 Digital Camera
Jun 01, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
May 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
MotorGuide Tour Series Freshwater Bow Mount 109lbs Thrust 36 Volts 50" Shaft 21 Mount Logo
Top MotorGuide Boating Experts
Mike
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a MotorGuide Boating Expert? Answer questions, earn points and help others
