Question about Rowenta Power Duo Iron
How do you remove Torq screws that have that annoying center pin?
    New Friend:
You Have to buy a 'security' torque set. I bought a set of security bits with 50 different types that included the one needed for the Rowenta Power Duo. It was only $9.00 at my local Harbor Freight store.
Posted on Nov 23, 2010
SOURCE:
How to remove cord on Rowenta DZ2061
Your iron probably has tamper proof outer screws with a center pin...don't be intimidated. First, try to remove the screws with a tiny screwdriver from an eyeglass repair kit. If that doesn't work, get a Torx T-20 nutdriver attachment.
If you have to replace the cord, here's a possible supplier: Smallappliance.com
Oct 05, 2012 | Rowenta DZ2010 Iron
I can find only one screw in the housing of the ep 8000 iron. What kind of screw driver does it take? Allen wrench doesn't engage.
Sounds like a 'TORX' head.
Does it look like a 'star' inside the screw head? A six-sided star? If so, then it is a TORX head.
Look carefully at it, and determine whether or not there is a small pin sticking out of the center.
The screw you are trying to remove is either a Flat-Head (-), a Philips (+) or a TORX (*).
You can get TORX bits almost anywhere, from the Hardware store, the Auto-parts store, to a Dollar store. You can get them with, or without, the little hole for the pin in the head.
You will probably want to buy a little 'set' that has multiple sizes of bits, and a driver, with an extension for reaching into those deep holes.
Jun 24, 2011 | Euro-Pro Steam Generator EP8001 Iron
Replace power cord. Has special screws on back plate torque screw driver won,t fit.
I am not familiar with your particular iron ... however, I am familiar with different types of "bits" I suspect yours are security "Torx". Torx look like a "allen" with points. Some call them "star". A Torx 'security' will be the star shape with a pin in the center, disallowing a regular Torx bit from entering. If you will take your Iron to the Hardware Store or your local Auto Parts store and show to the salesman, I am certain they can sell you the proper bit to remove the cover on your Iron. You may have to purchase a handle at the same time.
There are other types and yours may not be Torx. It could be any of many including a thing that looks like a philips but only three slots instead of 4 or a 'clutch' or it could be a 'one way' or other special bit.. The person at the store should be able to identify the appropriate tool immediately. If not, there are probably more than one store in your town ... go to he next and so on until you get the necessary tool.
Thanks for your question today @ FixYa.com
Jun 05, 2011 | Rowenta DZ1700 Iron
Tefal aquaspeed 260 No heat no light. Fuse OK
I had the same problem. Turned out to be dirty contacts on the thermostat, easily cured with a strip of sandpaper, but you need to dismantle the iron first.
  • Remove the 3 Torq screws in the heel plate (the purple triangular bit at the back, that you stand the iron up on when it's cooling off). One of the screws is a security screw so you'll need a special screwdriver, though I suppose you could risk drilling it out if you're desperate.
  • Prise off the bottom section of the heel plate, to reveal the cable connector block. Pull out the connector block (it's just a push fit).
  • Pull out the self clean / steam selector button.
  • Prise off the white plastic front cover (the one under the self clean button, that surrounds the jet spray nozzle).
  • Under the cover are 3 screws that hold the sole plate and iron body together. Undo them.
  • Now you should be able to separate the main components of the iron and get to the thermostat. Check the contacts - mine had a build-up of carbon from the arcing as the thermostat operates. Clean both faces with a strip of sandpaper, then reassemble the iron, being careful to align the temperature selection lever correctly.
Dec 22, 2009 | Tefal Irons
Rowenta Iron-Professional Luxe The power cord seems to short out when you move iron. You can wiggle it next to the movable ball and it clicks on and off. The two screw heads on bottom appear to be special...
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Oct 22, 2009 | Rowenta Irons
My Oreck Cordless Iron leaks constantly. What can I do to stop the leaking?
Find where the leak is coming from, and coat the leak or crack with silicone.
Jul 29, 2009 | Oreck Cordless Speed JP8100CA Iron
Drain screw
He, if the repair was done within their warranty period, try calling their service department. It should be covered...beyond that, I would say that someone either overtightened or cross threaded the drain screw. You might warm up (but not fully presurize) and see if you can loosen it 1/4 turn counter clockwise (no further) and let it cool before removing.
Aug 05, 2008 | Rowenta DG-980 Iron
Taking a Rowenta DX1900 Apart
To get the base off, you have to remove the 2 screws from the face.
the button for the reel has a screw behind it, that needs to be removed.
Take a thin piece of metal, like a spark plug gapper, and slide it in the side to push back the tabs. You have to do it on each side. Remove button and take out screw. The base will come off.
Now you need a special torx srewdriver that allows for the center of the screw to enter the screwdriver.......
Learned the hardway and didn't have the correct torx..... Good Luck
Feb 27, 2008 | Irons
Spray button stopped working
We had the same problem and we fixed it by taking off the handle section and putting in a new spring (it looks like a little pin actually).  We tried it because we were not in the US anymore and didn't mind breaking it so do this at your own risk.  It did work though.  When (if) you open it up you'll see how flimsy the pin is.  Its hardly surprising.  Go lightly wit the button after this.
Nov 06, 2007 | Rowenta DG-980 Iron
Rowenta Power Duo Iron Logo
200 people viewed this question
Top Rowenta Irons Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
