Question about Home
I am trying to loosen the plastic nut under the toilet tank. The tank seems to be leaking from this spot.
    New Friend:
  • 17 Answers
I use a spud wrench, cheap one is about 6$ but, check your rubber flat washers on your tank bolts,they get hard and crack, or it's possible that your tank has a hairline crack running from tankbolt hole to tankbolt hole, both are common problems
Posted on Oct 24, 2010
SOURCE:
How can I remove the Flushmate 503 to access the mounting screws at the bottom of the tank?
You will need to remove the china holding tank from the toilet bowl by removing the nuts on the underside of the china tank.
After you have the tank off the bowl, remove the two plastic lock-nuts used to mount the Flushmate into the china tank and slide the Flushmate out of the china tank.
After you install the new tank-to-bowl bolts & washers, reverse the process to reinstall the Flushmate unit and remount the china tank.
Mar 01, 2013 | Home
Water leaking from around the base of the flush valve. I purchased a new gasket but cannot remove the jamb nut. The wrench seems to deform the plastic and the whole assembly turns rather than the nut. Any...
Use a gripping pair of pliers but still be gentle hold the assembly and then try to turn it make sure you are not turning it the wrong way in plumbing somethings turn the opposite direction than normal when tighting and loosening
Sep 14, 2011 | KOHLER Archer Toilet Tank, White
The plastic nut on the inside of the tank which holds the handlle in place constantly loosens up. Solution?
Hi emaurice...
To stop the nut from loosing up, take the nut off of the flush handle unit,make sure the unit is dry and put a small amount of silicone sealant on the threads of the flush handle unit close to the tank and reinstall the nut.
If you do this before bedtime would be better just after the last time you use the toilet before going to bed.
Let the silicone cure overnight and that will solve your problem of the nut coming loose but still will be removable if you have to take it off.
Please take time to rate me
Aug 20, 2011 | Eljer 141-0220-00 Toilet Tank White
Loose tank-how to fix
There are two large plastic nuts holding the tank to the bowl underneath and behind the bowl. You need to retighten the plastic nuts. You almost have to lay on your back on the floor to look up under the the tank.
Nov 25, 2010 | Kohler Memoirs toilet tank with Stately...
Jacuzzi sent me new rubber gasket for attaching flapper assembly to tank-(held in place with a large white plastic nut) Does the totally flat side of the rubber washer face the tank or away from the tank?...
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Aug 31, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
When flushed, the handle doesn't lift back automatically. I have to lift it manually.
Try loosening the plastic nut on the back of the handle (inside the tank) a tiny bit. :)
Mar 17, 2010 | Mansfield Plumbing Products Mansfield...
I installed the tank on the bowl hand tight, but it seems loose
thats a tough call, i used to battle with this when i was out in the field fixing many toilets,...if it don't leak, it's tight enough,..concerning the rocking, i used to place little shims under tank to stop it rocking,....don't force nothing,.and make sure your hand tight is good-n-snugg. good luck, good question, cracklin joe
Jan 04, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Water continues to flow after tank fills
you need to replae the float valve
go to Ace hardware and get a fluidmaster fill valve kit
they range from $7 to $9
come back
turn water off at riser( up to the tank
flush toilet remove tank top lift the flapper up and lt water drain
get bucket or small bowl
remove the plastic nut that holds the silver risr or flex line
look up under the tank there is a large lock nut screwed onto the plastic fill tank assembly
remove the nut (try to place bowl to collect wter left in tank
remove the float assembly from inside the tank
Install new fluidmaster ( flow step by step directions
good luck
Jan 05, 2009 | Home
Home Logo
128 people viewed this question
Top Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
