Question about Konica Minolta magicolor 2430 DL Laser Printer
Minolta MC 2430dl has media jam, if fixed, says black toner or magenta or cyan or yellow not installed, but they all are installed and definitely have ink in them.
    New Friend:
Remove the cartridges. vacuum residue. clean copper contacts on cartridges with a pencil eraser. reinstall.
Posted on Nov 19, 2010
SOURCE:
What is the konica minolta black imaging unit ?
its the image unit below the black toner lower right. the image units go from left to right yellow magenta cyan and black.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 09, 2014 | Konica Minolta bizhub C250 All-In-One...
LBP 5970 --16 PREP.Y TNR
Hi!
Y toner is your yellow toner that needs to be replaced!!C is cyan,M is magenta and BK is black!!
Enjoy!!
Jan 29, 2011 | Canon Color ImageRunner LBP5970 Laser...
Minolta 2430dl, cyan, magenta, and yellow toner cartridges all show empty. Black shows 42% remaining. How do I get printer to print?
Some printers will refuse to print _anything_, until you replace/refill _all_ of the empty toner cartridges. So, replace/refill.
Dec 30, 2009 | Konica Minolta Office Equipment & Supplies
Error code c-2833
CAUSE: LD Power becomes saturated when performing Auto Gamma adjustment in a low humidity condition.
SOLUTION: Perform the following adjustment:
1. [Utility].
2. [Machine Admin. Setting].
3. [System Setting].
4. [Expert Adjustment].
5. [Process Adjustment].
6. [Toner Quantity / Exposure].
7. Select the proper Exposure Adjustment [Yellow, Magenta, Cyan, or Black] by using the Next/Previous button.
8. Select Standard then select [-2] under Exposure.
9. Press OK.
Notes:
a. If the problem persists, replace the problem color drum since the cause of the SC is the combination of drum characteristic and humidity.
b. The following codes = colors: C-2831 = Yellow; C-2832 = Magenta; C-2833 = Cyan; C-2834 = Black.
Dec 03, 2009 | Konica Minolta bizhub C250 All-In-One...
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Streaks & Smears after changing toner cartridge.
Remove all of your toners and clean them off. Replace each one and make sure they are well setted in the unit before going to the next one. Make sure the carosel turns smoothly and nothing is hanging up on the sides. Reboot the whole printer and let it settle for 5 mins before printing. toners come lose sometimes when you turn carosel around. Hope this helps you these printers are a ***** to deal with ,but when they are right there great.
Sep 08, 2009 | Konica Minolta magicolor 2430 DL Laser...
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Error 2408
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
202 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
