I have a evcon eb12b heat pump, it works intermitantly on heat, ihave replaced the contactor, and have 24v at the contactor, come times the heat pump will come on sometimes it wont, The hvac repair guy wants to replace 900.00 worth of parts cause hes not sure of the issue
  • 3,074 Answers
Does this unit have a capacitor that is hooked up to the motor, as it may be the capacitor or motor, of course this is just a guess as I am not there to see it. I guess you can push in the contactor a few times and make sure all is coming on like it should, might be the control board. Just a matter of pluck and chuck. Good Luck Tim
Posted on Oct 24, 2010
SOURCE:
Contactor does not activate on 1 ton 208 V 1PH residential Heat Pump condenser. It cools and heats when manually pushed in. A green flash comes from the contactor when pushed in a and released
Green flash is the sparking, which is common which elderly contactors. It should likely be replaced. Test for the problem by checking for continuity (ohms) on the solenoid coil of the contactor. (The two small wires on the side.) Test also if you get 24v AC on those two wires when the A/C is turned on. If you have no 24v, it's a thermostat or wire problem. If no continuity, replace the contactor. (Always pull the wires off the contacts when checking the contacts for continuity.)
Nov 11, 2010 | Heating & Cooling
Fan Rons Furnaces run Heat pump or AC will not run
I would check to see the contactor is functioning. The contactor is the big switch looking thing in the middle. The power hooks to this. First check to see if it pulls when inside is calling for air. If it does not than check to see that there is 24V going to the coil of the contactor. The 24V wiring will be connected to the sides of the contactor. Some contactors have the two wires on one side (this is usually on a Rheem) If the contactor is pulling in check and see that you have at least 220V running through it. I suspect that one side of the contactor is burned or has ants or some thing in it. Remember you are dealing with high voltage and take appropriate precautions. The capacitor can hold electricity in it even if power to unit is shut off.
Jun 30, 2010 | Heating & Cooling
No heat at night
You have a poor low voltage connection from the thermostat or a bad contactor.The contactor is the main relay control inside the condensing unit. The incoming voltage wires connect to it.
Contactors are inexpensive. I would change that first.
Check all your low voltage wires in the condensing unit for loose connections.
Dec 11, 2009 | Coleman Heating & Cooling
Safety fuse trips in my 75VA control transformer
Yes, the contactor OR the wiring to it could have a problem. The transient suppression diode that might be associated with the contactor driver could also be shorted.
An ohmmeter is your friend in troubleshooting this.
Nov 14, 2009 | Universal Electronics UEI UET79R 75VA...
Ruud heat pump outside unit not starting. Open and found contactor disengaged even though I have system on from inside. Low voltage wires come out of a circuit board checked for 24v, none. Then bypassed...
If you are getting the low voltage to the relay and it is not closing, then the relay may be either bad or stuck. Disconnect the 220v and see if the contacts can be manually closed. I always use a piece of wood or something non-conductive. If the contacts will close manually, try re--energizing the circuit to see if the relay will now close on its own. If not, you are probably looking at having to replace the relay switch. I had to replace mine last year. As always, be extremely careful working around electrical boxes and capacitors.
Jul 04, 2009 | Heating & Cooling
Goodman CPB 42 Heat/air packaged unit
did you turn off the air handler when you changed the contactor could have shorted and blown a fuse on the control board. did you get a 24v coil on your contactor. do you have 24v at the contactor when unit is calling. check your wire connections
Jan 31, 2009 | Heating & Cooling
A/c help
Do you have 24volts at the contactor when the T-stat. is set to cool or heat if unit is a heat pump? The outside unit must have 24v at the contactor to engage
Oct 19, 2007 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
