Question about PfaFF Creative 7570
Needle hits bobbin outer casing
on my Pfaff Select 3 the needle hits the outer casing of the bobbin - the thing where the bobbin case sits in and which turns with the needle movement.
I DESPERATELY need help as I have Uni deadline on tuesday and need to do sewing for that.
Thanks, regards
Doro
  • 1 more comment
  • Anonymous Mar 13, 2014
    cant align bobbin casing properly and needle hitting casing
  • Anonymous Mar 22, 2014
    needle is hitting the bobbing case and stopping it going around take the needle out then bobbin workd fine I have the pfaff 2044
  • Anonymous Mar 24, 2014
    Machine can not sew because needle is hitting where bobbin goes in.
  • 323 Answers
Your hook/needle timing is off and it needs to be seen by a technician before you damage the hook. Some dealers can do a 24 hour repair for an additional charge.
sewman7
Posted on Jun 09, 2008
Hi I have a pfaff industrial zig zag 428, the bobbin has stopped all rotation
bobbin case should be stationary, bobbin itself is rotated as thread unwound, check hook timing. Simply turn hand wheel towards you and watch needle go down, when it reaches lowest point turn it slowly until needle rises 3/16" or so. Hook should be behind needle and slightly above eye.
Feb 12, 2014 | PfaFF Sewing Machines
Needle Jams In Bobbin Case Area pfaff 1540
First, make sure there is no debris and scraps of thread in the bobbin area. I'm sure you did that already. I assume you also tried it with another thread just to be sure. I would suspect that the timing went out of whack. The machines depend on a synchronization between the needle motion and the bobbin action underneath. I once had a Singer that slipped and I had to reset the timing. If it is the timing synch problem then it would happen consistently and not work sometimes and then not work other times. G
Jan 27, 2014 | PfaFF Sewing Machines
Thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
Have needle heating the house of the bobbin case on pfaff 1222e
Rabi. Do you mean Hitting on the bobbin case/shuttle? That is a timing issue.
Nov 29, 2012 | Sewing Machines
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
I broke a needle while sweng,now my needle hits my bobbin case on my 2030
it's very possible that when you broke the needle it caused the machine to go out of time & would have to be retimed at a sewing machine repair shop
Mar 12, 2012 | PfaFF Tiptronic 2030
Needle hits the bobbin casing.
check to see the bobbin is in correctly first, is the needle in the centre?
Nov 23, 2009 | Sewing Machines
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Sewing Machines Logo
691 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
