I want to clear my nova navigator pc BIOS password.i want to change the operating system of that pc.That so i want to clear that
    New Friend:
Forget login password
Posted on Dec 13, 2010
Testimonial: "thank you"
    New Friend:
Unlock krne ke liye usb router chahiye.
Posted on Apr 24, 2015
SOURCE:
Is asking for password when coms on forgot it
There is usually a jumper on the motherboard that you can remove to clear BIOS settings including password if the password is a request of the BIOS. If it is a Windows or other operating system that is asking for password you are probably going to have to reload operating system. Look on motherboard for small jumper with the word BIOS imprinted next to it. Make sure power is off, remove jumper and restart pc. When BIOS comes up do not set password protection. Shut pc down, replace jumper and your bios settings should be fine. Good luck
Feb 24, 2014 | E-Machines Computers & Internet
I need password for bios to dell dimension 3100 desktop?
marwan_vaqub,
Dell does not supply bios passwords for Desktop systems. You would have to change the motherboard jumpers to clear the bios password. For help to clear the password please contact Dell Support for system ownership verification and they will then help you resolve clearing bios password.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 10, 2013 | Dell Dimension 3100 PC Desktop
Bios password remove
Basic input/output system, or BIOS, is an interface to start and load the operating system. Making changes to the BIOS will change the way the operating system operates. Sometimes to make changes to the BIOS, you will have to enter the BIOS password. If you have forgotten the password, you can bypass it.
1.Download and install a BIOS utility such as CmosPwd or KillCMOS (see Resources). These utilities will remove BIOS passwords provided you are in MS-DOS or Windows mode.
2.Locate the jumper switch on the laptop's motherboard. You can identify the jumper switch by CLEAR, CLEAR CMOS, JCMOS1, CLR, CLRPWD, PASSWD, PASSWORD, PSWD or PWD label. Once you have found the jumper switch, remove it and place it over the pin that is not covered.
3.Locate and remove the CMOS battery for at least 5 minutes. This will reset the BIOS password. Then enter the generic BIOS password to enter the BIOS.
I hope you find it very helpful. Thanks.
Sep 05, 2011 | Toshiba Satellite A300-0CF035 Notebook
Please tell me master password key for power-on password of hp compaq nc6220.i have already tried to remove bios battery but i can not remove my power-on password
You would have to perform this in the BIOS ( Basic Input/Output System) Here are the steps:
1. Restart your computer. 2. Enter the BIOS by pressing the designated key (usually F1, F2, or Delete key).You will be able to enter the BIOS by pressing any of those keys..(this is the black screen that appears before your window starts up) 3. Inside BIOS, navigate the "menu" option by using the "arrow keys" 4. Search for "user password,system password, or power-on password" as it may vary depending to your system. It should show you "enabled or Active" and you have an option to "disable it" 5. Make the "disable password" press enter. 6. Click the "Save Changes" or "Save Changes and Exit" option in the system and it should not ask you for a password the next time you turn your computer on.
---for your reference, the command help is shown at the bottom of the BIOS screen which will guide you which keys to use while navigating inside it.
Aug 23, 2011 | HP Compaq nc6220 Notebook
Passworld clear for Bios
Im afraid you have no choice but to restart your entire BIO's
They're two ways to do this, both include opening the case
  1. Remove the BIO's jumper and restart then reinsert
  2. Remove the CMOS battery and reinsert
Only reinsert when you have discharged all static electricity and the computer is powered off
Good luck
-Ryan
Mar 06, 2011 | Computers & Internet
Bios unlock password for nova netpc
sir,
how to nova net pc unlock bois setting 945 (atom intel) motherboard
Jan 28, 2011 | Computers & Internet
I forget the hdd password
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 15, 2011 | Computers & Internet
After boot, appears ENTER PRIMARY MASTER HDD USER Password i need the password @ solution to boot up my lappy... thanks
How Do I Change the Primary Master HDD User Password?
Prior to loading an operating system, your computer will first execute the BIOS program. The BIOS has an extra password feature, called the hard disk drive (HDD) user password, that can't be bypassed and provides a layer of defense to keep your data secure. To change an existing HDD user password you will have to load the BIOS menu, which is only accessible during the computer's operating system reboot procedure.
Instructions
1. Close any windows that are currently open on your computer. Eject any discs inserted into the optical drive and disconnect any peripheral USB devices.
2. Open the "Start" menu and select "Shut Down." Turn on your computer once the operating system finishes shutting down.
3. Press the key your computer uses to load the BIOS menu. For example, with Dell computers tap "F2" when the "Press F2 for Setup" option appears. Press the "Access IBM" key on IBM laptops or "F10" on HP desktops.
4. Navigate to the BIOS tab that contains the HDD password option, which will usually be the "Security" tab. Some computer manufactures instead include the password option in the "Advanced" tab.
5. Scroll down to the option labeled either "User Password" or "BIOS lock" and hit "Enter." Type the current master HDD user password when the prompt appears and press "Enter."
6. Input a new HDD user password and hit "Enter" again. Navigate to the BIOS tab labeled "Exit" or something similar.
7. Move over to the "Save and Exit" entry and press "Enter." Select "Yes" and tap "Enter."
Nov 15, 2010 | Acer Aspire 5610 Notebook
Password
If it's an operating system password, then press F8 at start up to enter safe mode, log in as administrator, from here you can go in and clear user passwords. If it's a bios password, it can't be cleared in a Thinkpad. If you have any trouble or if it's a bios password let me know.
Jul 01, 2008 | Microsoft Windows XP Professional With...
I am trying to bypass the password that was put onto my computer and I am not sure how to reset my computer completly
If you can not enter your operating system because your being asked to type in the password than you will not get into windows unless you re-install windows or have the correct password. If you can not get into your bios because you or someone else set a password up for the bios. You can re-set the bios by clearing the bios settings. This entails moving a jumper on the motherboard to clear the bios & than re-seating the jumper to it's default setting. After doing this you'll have to enter the bios & re-set up all the settings for the system or your operating system may not load correctly.
Mar 04, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
665 people viewed this question
Ekse
Marvin
Marvin
