Question about Candy FP855 Electric Single Oven
I have a fpp 406 x candy oven. I am not sure what I have done, but it will not heat up - I thik it may have something to do with the appearance of a symbol in the display, but cannot remove it. Please help me.
2 Suggested Answers
SOURCE:
barkencoa
  • 3463 Answers
SOURCE: CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Posted on Feb 22, 2010
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
Oven will not heat on either oven
Candy Oven not heating? How to replace a Candy fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
You searched for candy element How to Repair Home Appliances
Dec 16, 2013 | GE JTP45 Electric Double Oven
Why does my Candy oven Model FPP 406/1x trip the RCD in my fuse box after 3 minits warming up?
as an appliance engineer sometimes the oven element can be at fault, although this always the case, it could be the thermostat also as they are both interplay when the oven is heating up, they could both be tripping the RCD as the earth is detecting that electricity is becoming live due to a component leaking electricity.
you could try replacing both of them with caution (turning the electricity off in the house ect.. using safety equipment)
a good site to use for those components is the following;
Spare Parts Accessories for Electrical Appliances QuickSpares
usually if they don't have the item in stock on the website you can use the contact option and they usually respond pretty quickly and let you know if they can get the item ( most likely )
Apr 19, 2013 | Ovens
My candy fan oven has no heat when turned on
If the fan is working o/k, then it is going to be a faulty oven element, fitting a new one should solve the problem.
Mar 29, 2010 | Candy Ovens
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 | Ovens
CANDY OVEN
Feb 22, 2010 | Candy F248P Electric Single Oven
When i switch the oven on the oven trips the main circuit. the oven used to work normal then it started to trip out after it had been on for a long period. you could leeave it off for 10 mins then it would...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Feb 15, 2010 | Candy F248P Electric Single Oven
Oven not heating but fan working
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for candy element How to Repair Home Appliances
Jan 16, 2010 | Candy Ovens
Candy oven noisy fan
Noisy fan means bushes are worn. cant be repaired. needs replacement. Quote model of oven to spare parts supplier and replace. Make sure power is unplugged and not just switched off before repairs are done.
Sep 14, 2009 | Candy FP855 Electric Single Oven
Candy F254/3X single fan oven, grill works, oven doesn't.
If fan is working o/k, then you need to fit a new oven element
Please`rate my solution.
Thanks.
Aug 24, 2009 | Candy F248P Electric Single Oven
Element needs replacing
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Candy Ovens
Candy FP855 Electric Single Oven Logo
463 people viewed this question
Top Candy Ovens Experts
Thomas Perkins
Thomas Perkins
ray gallant
ray gallant
Dado
Are you a Candy Oven Expert? Answer questions, earn points and help others
