Question about Dishwashers
Pdw8100 or very similar model
This model has a horizontal latch/handle that is slush with the front and kind of "up and under" . It is not visible. It will not open the wishwasher. It feels "loose" and does not "click" into place to open the door when "squeezed". I've run it through at least 3 cycles hoping something would let it loose to open but it doesn't. Suggestions? I dont see any way a screwdriver is going to open it. I would be breaking the whole handle to try that and I don't want to damage it. Is there some cycle or button that will cause it to release???/ It is brand new. Maybe used 10 times.
SOURCE: dishwasher door latch
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Posted on Dec 06, 2008
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Posted on Jan 16, 2009
  • 3917 Answers
SOURCE: Amana Dishwasher Mod. ADB1500AWQ, Door won't open.
Please check whether the plastic pins are broken.
I removed the inner door panel and found the handle broken. It has integrally molded plastic pins that provide a pivot for the handle to push against the release assembly. These were broken off. Also noticed that there were some small fingers molded on the back of the switch panel that were snapped off. I'm not sure what these are for and I can't see how they are needed for the latch operation. My hunch is that they aid in positioning the handle during factory assembly. I'm NOT going to buy a new switch panel to replace these!
I don't know why the handle broke but it did so in stages. I think one pin broke, and then everything else broke because of added misalignment and stress. The good news: a new handle only costs about $10 and I'll have it in a couple of days. Thanks
Posted on Apr 24, 2009
SOURCE: dishwasher door will not open.tried
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Posted on May 30, 2009
SOURCE: Amana Dishwasher door will not open. Latch you grap is very loose
We have the same problem and I bought the latch locally for $26.00 now trying to figure out exactly how to get the door apart to replace.
Posted on Mar 04, 2010
98 crown victoria hood won't latch
Let's starts at the beginning, inside the car. When you pull the release cable, is it moving freely? Sometimes cables dry up. This may be your issue. You can buy "cable ease" which is a graphite lube. *Its can be messy so be careful and bring plenty of rags!!!* Follow the directions on the package and you should do fine.
Under the hood you have 2 latches, the one which holds it closed tight and another attached to the little handle that's under the hood. The one that holds it tight is the one attached to the cable/handle inside. Find the latch and spray it with a penetrating oil (WD40 or Blaster work well for me) You may want a friend's help for this part. You'll want to spray it, trigger the mechanism with a screwdriver or similar and then have a friend pull the handle inside. You'll need to repeat this a number of times until the mechanism is moving freely. I recommend spraying the latch with white (lithium) lube to protect it and keep this from happening again. You can spray and move the secondary latch in a similar manner to fix and maintain it.
*** I'd recommend trying the latches under the hood first***
Out of the two, I've found it more likely the source of the problem and easier to fix as well. Good luck and please let me know how you made out!
Jan 18, 2012 | 1998 Ford Crown Victoria
PDW8100 Dishwasher went through cycle several times, but I am unable to open the door. Is there a way to get it open? Thanks, Barbara
When your dishwasher door has a problem, check these:
Door seal
Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Jun 07, 2008 | GE Dishwashers
Rear seat removal, fx yamaha jet ski, latch will not release the seat
As bad as this sounds its the only way. Grab yourself a 2x4 and a nice size prybar.
Lay 2x4 across the back grab handle as to not damage it then put prybar directly under seat latch and pop it up.
Oct 29, 2011 | Yamaha 12V Air Pump
We broke the door handle on our Malber 1000 Can we order a new one and can we fix it ourselves?
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
Sep 26, 2010 | Malber WD1000 Front Load Washer/Dryer
How to open the hood with a totally flat battery
i think it could be one of three things; the cable is detached from the handle, the cable is broken inside the sheathing, the cable sheathing is not anchored at the hood latch.
in the case of the cable being detached from the handle, look under the dash and inspect. if the cable is visible, use a pair of pliers to yank it. in the other cases you will have to gain access to the latch from under the car or through the grill. then it's a matter of releasig the latch with a screwdriver or similar tool which could prove to be difficult.
Mar 27, 2010 | 1998 Porsche 911 Carrera
I have a 1994 chevy lumina euro, and the driver side door does not work, something on the inside has come out of place, how do i fix this?
If you mean that the door handle won't work, you probably have a broken connector on the door latch. The only way to repair this is to pull the door panel off. Kind of tricky if you haven't done this before. A trip to the library and a look at a Motor's or similar repiar manual will show how to remove. Sometimes the plastic clip that holds the horizontal rod breaks. Most of the time it has just popped off. Hope this helps.
Nov 02, 2009 | 1990 Chevrolet Lumina
I am working on a 2000 Mercury Cougar and the hood latch won't release when the handle is pulled. I can hear something moving under the front of the hood when the lever is pulled but nothing happens. ...
yes you have to go into the chamber from underneath with a crow bar or similar tool to release the hood latch. once opened check the cable and the latch and with a little luck a few squirts of WD40 is all that will be needed.
Aug 21, 2009 | 2000 Mercury Cougar
if you hit the lock button a couple times, will it finally lock?
If so, then you will need to take door cover off and lube up the connectors as they probably got corroded.
Aug 14, 2009 | 2000 Ford F350 Super Duty Super Cab
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Driver's side door won't open in the cold
Power Door Lock Operation (Front Doors)
The front doors do not have traditional door lock actuators. They have electronically controlled door latches that will operate depending on the status of the door lock system. This status is determined by the front door modules and the last known state of the lock system. If the last known state is LOCK, the latches will not release when the door handles are operated. If the last known state is UNLOCK, the latches will release when the door handles are operated. The front doors are also equipped with red door lock status indicators. The front door modules will supply power and ground to the indicators to illuminate them when the lock system is in a virtual state of lock. The indicators will not continuously illuminate when the vehicle is locked. They will illuminate for approximately 5 seconds after a lock switch activation or after a door handle has been operated and the front door modules are in a virtual state of lock. For further information on the front door latches, refer to Power Door Latch Description and Operation .
I would assume they check for DTC'S - diagnostic trouble codes ?
DTC B3062 Front Door Key Lock Switch Circuit
• DTC B3067 Front Door Key Unlock Switch Circuit
DTC B3849 Exterior Door Handle Switch Circuit
The left front exterior door handle and right front exterior door handle switch signal circuits provide inputs to the driver door module (DDM) and passenger door module (PDM) when an exterior door handle switch is activated. These inputs allow the door module to detect a door open request. The door modules provide voltage to the door handle switches. If the door module detects that a ground is applied for greater than 30 seconds continuously, a DTC is set and the door module will ignore the door handle switch input.
Free wiring diagrams here
Enter vehicle info. year , make , model and engine size . Under system click body & accesories .Then under subsystem click power locks . Click the search button then the blue links
Cadillac CTS Door Handle Repair Micro Switches Replacement 2nd Gen
Aug 10, 2017 | 2006 Cadillac STS
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
