Question about Sony PlayStation Portable (PSP) Console
Psp update problem
Hey when i tried to upgrade my psp either via UMD or memory it says (DADADADA)
  • 4 more comments
  • davidkay Jun 12, 2008
    same thing he said but its when i put in my game. :/
    it sucks.
  • sharingan7 Jun 23, 2008
    every time i try to update my psp its says (DADADADA)
    why does this keep happening
  • kj52 Jun 23, 2008
    I trided to update and it sad it going to delet my memory stick and it was on 10% so i turned it off and turn it back on and the green light comes on but you don't see nothing on screen so what do i do?
  • almonte Aug 01, 2008
    I trided to update and it said it going to delet my memory stick and it was on 55% so i turned it off and turn it back on and the green light comes on but you don't see nothing on screen so what do i do?
  • Anonymous Aug 23, 2008
    when i try to upgrade it comes up with (dadadada)
  • Anonymous Dec 25, 2008
    When i try to load Tiger woods 09 it tells me to upgrade from 3.40 to 4.01. But then fails withcode (DADADADA) Please advise.
  • 67 Answers
You need to get (buy) a pandoras battery that will unbrick your psp (datel battery).There are guides google (unbrick psp) that will help you to unbrick your psp , you could try to downgrade using pandoras battery and install custom firmware (backup your firmware when its says to) and then install sonys firmware if you want :P
Posted on Oct 14, 2008
Make sure you've created a upgrade folder and make sure when you name it its like this: UPGRADE
Posted on Jun 12, 2008
I KNOW even the upgrade file is showing on my psp, when i press it it, says DADADADA
I've did that ages ago but still no solution, it still say DADADADA
Everytime i started to update my psp to version 3.51 it tells me that THE GAME COULD NOT BE STARTED (DADADADA). what is this and what will i do with this? my current version right now is 3.40 OE-A
If u r trying to update ur psp by any umd in this firmware, It may not be possible so all u have to do is download the update file(official update whichever version u like) and copy it inside a folder named UPDATE, the UPDATE folder should be inside a folder named PSP. The folder PSP could be found at the front(root folder) or when you open ur psp drive by using a computer...
NOTE: a)Do not cancel or switch off the psp during update...
b)Do not rename the update that you have downloaded...
Mar 10, 2011 | Sony PlayStation Portable (PSP) Console
My psp ver 4.01 is not working. Help me guyz!
psp firmware is corrupted, you be need to continue thats update..
1. update via UMD, the umd that are use must have same firmware version or higher (5.03). check it in other psp. make sure you have a fully battery, then turn on psp.
2. update using sony media go, it a pc client for sony device.. connect psp to pc via usb cable, you will need a internet connection on pc. and it will update to the latest version - 5.51.
hope this help..
Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
The game cant be played DADADADA, and yada yada, its different fo
go to the playstation network site click psp and system updates and you can update it from there.
Apr 03, 2009 | Sony PlayStation Portable (PSP) Console
PSP System software Upgrade
Go to your recovery menu and disable execute boot.bin and plain modules. This should work.
Feb 14, 2009 | Sony PlayStation Portable (PSP) Console
PSP-2000 Update problem
Firmware 3.60 is rather old, I would suggest upgrading to 4.01 or something in between before jumping to 5.02, this may clear the problem.
The network update feature of the PSP usually works better than when downloading via PC because there is less room for error. After you upgrade to a 4.xx firmware, try using the network update again.
Dec 30, 2008 | Sony PlayStation Portable (PSP) Slim...
I upgraded my psp with a UMD
you updated to ofw official firmware you will have to downgrade
Dec 20, 2008 | Sony PlayStation Portable (PSP) Console
PSP Error 80020148 when playing FIFA 08 UMD
alright turn off your psp by holding down the power switch for atleast five seconds. when it is turned off hold down the right trigger (the R1 button) then at the same time hold down the power switch button to get to the recovery menu. after that go to configuration then somewhere amongst all of the displayed lines one of them should either say no umd or umd required toward the end of the text. if it says umd required change it to where it says no umd. then go back and go to advance then advance configuration and disable all and this should solve your problem. hope i helped.
Feb 21, 2008 | Sony PlayStation Portable (PSP) Console
PSP with corrupt firmware 3.03-C (Code DADADADA)
for mat your memory card if you have one and goto options and reset to factory options
Feb 15, 2008 | Sony PlayStation Portable (PSP) Console
NEW PSP TIGERWOODS 08 XMAS PRESENT
Remove your UMD, start your psp, go to settings, system settings, restore default settings, and try again.
Alternatively, you could try to update your firmware, as the game might need a higher version system. Please refer to the manual given below.
WARNING: HAVE YOUR BATTERY CHARGED 100% BEFORE ATTEMPT TO UPDATE FIRMWARE, OR YOU END UP WITH A BRICK.
Dec 26, 2007 | Sony PlayStation Portable (PSP) Console
PSP game won't play
Now I'm so Sick ! OF MY PSP CAUSE WHEN I PLAY GAME IT ALWAYS SAY THE GAME COULD NOT BE STARTED (80020321) PLEASE I VERY NEED HELP HELP ME!
Dec 25, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
528 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
