Question about Bosch Tassimo TAS4511UC Coffee Maker
Orange light stays on after a disk is put in and wont go to the green lite and make the coffee my coffee maker is new had for 2 weeks what is the problem
    New Friend:
I had the same problem the manual says to wipe the barcode on the Tdisc but it didn't work for me. Instead I figured it must be the reader which is where the disc slots in. I wioed it clean and it works fine now.
Posted on Jun 27, 2013
5 Suggested Answers
SOURCE:
cmccune04
  • 214 Answers
SOURCE: Orange needle cover has come off my krurig coffee
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Posted on Apr 18, 2010
SOURCE: coffee maker wont stay on after making a pot of coffee help
i downloaded the owners manual at http://www.cuisinartwebstore.com/detail/CUI+DGB-300BK
and resolved it by reading the manual. ( i had lost my original )
Posted on May 17, 2009
  • 4088 Answers
SOURCE: The cofee maker my dad gave me wont make any coffee
You may need to run a pot of white vinegar and water (50/50) through several times to flush out the line and heater. Make sure that the plate under the pot is getting very hot or it won't pump water from the reservoir. Hope this helps!
Posted on Feb 10, 2010
SOURCE: Mr. coffee died
got the same problem, im going to take it apart and look at the electronics. im sure its due to water getting in there
Posted on Sep 07, 2010
When I switch the machine on the orange light comes on but nothing else happens lid won't shut
you probably don't have the disk in straight. It does take a push to get the lid down. The orange light will stay lit until it is ready to perk
Sep 27, 2014 | Bosch Tassimo TAS 4012 Coffee Maker
I have a bunn cwtf twin,I put new ready lights on both side work for about a week and the they wont light up. and the side the the faucet only brews warm coffee. but the other side does find. HELP
The green ready lights do not last that long. We never replace them on units we service. They are cheaply made. Each side of this coffee maker has its own thermostat. Check to make sure the thermostat is on all the way. If it is check the voltage on the warm side. Make sure it is in the 208v area. This warm problem is 85% the thermostat not set right and or needs replacing.
Apr 28, 2014 | Bunn CWTF Twin TC Coffee Maker
Bosch Tassimo TAS4513UC 1-Cup Coffee Maker manual
I looked up your problem and found the same one was answered previously on fixya. I have copied and pasted the previous answer here for you. Good luck and I hope you have a great day!
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Mar 25, 2014 | Bosch Tassimo TAS4513UC 1-Cup Coffee Maker
DS charging..light stays orange...
It could mean that the Motherboard (Main Circuit) could be damaged or could be a fuse problem as you may have said. Although it actually might be the battery, there's one way to find out, if your friend has a DS Lite, ask them if you could borrow your battery for 2 seconds and put their battery in yours to see if it is the battery, if the same thing happens, its the Motherboard (Main Circuit)
Jul 06, 2013 | Nintendo DS Lite Console
The orange light on the start button comes on and nothing happens
prepare machine for use first.
half-fill water tank, switch on unit and insert yellow TDisk (service disc) barcode down. Close the locking unit securely loud click, press green light repeat these steps 3 times. After that you will have the stand by orange/amber. Remove the Service Disc and store in the recess behind the water tank, Insert a Coffee Disc, close the brewing unit with click and green light should be on. press and it should work.If not go to shop where pruchased. Warranty.
Dec 29, 2012 | Braun Tassimo Espresso Machine/Coffee...
Bosch tassimo t46 coffee maker
I have a problem with my bosch t46, I just bought it in Canada and returned to Aussie yesterday, when I plug it in all good orange light place disc in the green light comes on, but when i press and hold button both bottom red lights flash?
Any ideas what it could be very frustrating Thanks in Advance
Jan 06, 2012 | Bosch Tassimo TAS4511UC Coffee Maker
Ds lite green light is on but both screens are black and no sound
For GBA games the green light is meant to stay on. The orange light will stay on as long as its recharging. It will turn off when its fully recharged or when you unplug it
Apr 23, 2009 | Nintendo DS Lite Console
32Aap coffee brewer wont heat /older model
Green lamp is on when the thermostat board provides information that the temperature is set. It is either not properly connected or damaged.
Mar 20, 2009 | Fetco International Coffee Makers &...
Stay and Go coffee maker just quit during cleaning
Hang on. Wait until it has cooled and dried. Mine did this. About a week later, I tried it... Display was incredibly faint. But after some use, it "came back." Same as new. Everything is working.
Just... don't give up on it yet.
PeachPup
Feb 01, 2009 | Hamilton Beach Stay or Go 45234 Coffee...
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
Bosch Tassimo TAS4511UC Coffee Maker Logo
1,382 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
graybeard32301
timoboon2
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
