Question about Canon PIXMA iP1300 Printer
Ink carriage cannot be recorganised - Canon PIXMA iP1300 Printer
    New Friend:
  • 29 Answers
As far as I know, all injet printers are cheaper than its consumables (cartridges). If you haven't bought any new cartridges and you are facing problem with the printer, it is cheaper to change the whole printer and buy a new one than to go for new cartridges. The new cartridges can be fitted in the new printer.
Posted on Oct 24, 2010
  • devilsleg Nov 11, 2010
    I am also facing same problem but I don’t think buying a new one at the cost of cartage price is a wiser solution as ink cartage comes with new printer is DEMO INK .Besidides it seems to wastage for me to replace whole printer just for INK.
  • Satyendra Naik Nov 13, 2010
    Yes! You are right. But, I was talking about the maintenance cost. In case your printer fails to accept new cartidges, you can try new printer than going for a repair. The newly bought cartridge can work on the new printer too.
    The cartridge may not recognised due to ink clots on the golen contacts of the cartridge assembly. Those can be cleaned with Isopropyle alchohol. THose can be noticed if the cartridge is removed from the carriage and shows ink on its contacts.
SOURCE:
WHAT IS THE CARRIAGE CARTRIDGE
There are two different types of carriage units that you may be referring to depending upon the model printer you have. Older types of photo printers had two distinct carriages.
1. Carriage referees to equipment that travel left to right in your printer.
2. One is for the print heads that receive ink from your print cartridges and dispenses it to the paper that you are using.
3. The print head carriage that travels back and forth to accept replacement ink cartridges. Most of the time it is tucked to one side or the other and only travels when the printer is opened in a specific way to expose it for ink replacements.
In newer systems the print heads are built into the Ink cartridge, each color has it's own print head.
So in answer to your question the carriage cartridge is more than likely the container that you put your ink cartridge into. Unless you have an older printer and then it would or could be the carriage for either the print head or the ink. They some times need to be replaced. I had to replace that cartridge in an old HP2500 for as long as we had the printer. (4 years). Great machine high maintenance.
Aug 23, 2012 | HP Photosmart C7280 Printer
The print head does not move correctly. Ink cartridges do not light red. Orange flashing light flashes 12 times
I don't know what type of printer you have, but you might try cleaning the thin plastic strip you'll see at the carriage. It has fine lines on it and it tells the printer where the carriage is. If ink or dirt get on it, you will get carriage jams. Try this: get a soft cloth moistened with water and gently (!) rub it on the strip back and forth, moving the ink carriage to clean the entire strip. Don't use anything other than water as the ink is water soluble. Also clean the rod that the carriage moves on with alcohol. Sometimes dust and other debris gets on it and causes it to move jerkily.
Feb 26, 2011 | Office Equipment & Supplies
I have cx7400 want to change ink ---HELP
Turn off printer, unlock carriage, move carriage to replacement position. Replace ink tank. Or, turn on printer and immediatelly unplug power while carriage moving. Then move carriage by hand.
Aug 22, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Ip1300 does not recoganise the inks
cleane the bouth the cartridge head then try other wise change the cartridge
Oct 03, 2009 | Canon PIXMA iP1300 Printer
To realign my cartridge carriage i need to press "ink button" cant find it epsoncx5500
Turn on printer, and just unplug power while carriage moving. Unplug USB. Then move carriage by hand.
Jun 03, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Carriage jam on HP Officejet J5780 All-in-One
We have several of these in our company and the most common "Carriage Jam" cause is a glob of black ink in the bay on the right side. Once glob is removed, and "Carriage Jam" message appears again, press OK, and it prints fine from then on. Today the black ink glob was flat on top. Watch out for leaky cartridges, as the design of the particular HP device provides a nice catch pan for the tri-color ink cartridge, but not for the black one, so a leaky cartridge, besides being expensive and wasteful, can goop up the bay causing the carriage jam error message to try to get you to take a closer look.
Jan 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Carriage jam
I had this same problem with an HP2355v. There is a carriage directly below the print heads (on the right side of the printer) where the ink is dumped during the cleaning process. The carriage needs to be able to freely move (fore and aft). I noticed that my carriage was really gummed up on the left side of the carriage. I cleaned the edge of the carriage and the channel where it travels with alcohol and qtips. The carriage now moves with minimal effort and the error is fixed! Good luck.
Nov 17, 2008 | HP PSC 2355v All-In-One InkJet Printer
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Ink carriage
This is a tricky little printer. Here is your fix.
When you hold down the ink button for 3 seconds, the printer will perform a cleaning cycle.
But if you continue to hold the button for 10 to 15 seconds, it will then come ove to the opening where you can access the cartridges.
Apr 02, 2008 | Epson Stylus C44UX InkJet Printer
Horizontal ink smuges
You probably have a buildup of partially dried ink on the carriage itself. I don't know how difficult it is to access the carriage on your machine but if you can force-feed several sheets of paper under the carriage and put a broad streak of alcohol across the sheets, you may be able to 'wipe' the ink buildup off of the carriage without disassembling the machine.
Mar 11, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Canon PIXMA iP1300 Printer Logo
157 people viewed this question
Clive
Clive
old marine
old marine
Ekse
