Where do i find command prompt on my computer
    New Friend:
  • 29 Answers
It depends on the Operating System (OS) you have.
for windows 95-98-ME - type command in Run dialog box and press ok
in windows 2000,xp - type cmd in run dialog box and press ok
else specify your OS
Posted on Oct 24, 2010
SOURCE:
Hello, how do i do a factory reset with command prompt. the ususl method does not work as only optionsrepair and recovery ect are there. no reset option. dell latitudee7240 win 7. rstrui.exe. gets is
The instructions are:
  1. Turn on the computer.
  2. Press and hold the F8 key.
  3. At the Advanced Boot Options screen, choose Safe Mode with Command Prompt.
  4. Press Enter.
  5. Log in as Administrator.
  6. When Command Prompt appears, type this command: rstrui.exe.
  7. Press Enter.
  8. Follow the wizard instructions to continue with System Restore.
Restore To Factory Settings - Guide for Windows XP, Vista, 7, 8, 10..
before you try this go to this link and have a read up first.
factory reset with command prompt Google Search
Oct 29, 2017 | Command Computers & Internet
Tip
CMD Prompt here, add to folder context menu windows xp
Add the open cmd prompt to folder context menus also drives and MY Computer
Copy what's in the code area to notepad and save as cmd here. reg
CODE
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Drive\Shell\cmd]
@="Command Prompt"
[HKEY_CLASSES_ROOT\Drive\shell\cmd\command]
@="cmd.exe /k \"cd %L\ ""
[HKEY_CLASSES_ROOT\Directory\Shell\cmd]
@="Command Prompt"
[HKEY_CLASSES_ROOT\Directory\Shell\cmd\command]
@= "cmd.exe /k \ "cd %L\ ""
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\cmd]
@="Command Prompt"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\cmd\command]
@="cmd.exe /k \"cd %L""
on Jan 06, 2010 | Computers & Internet
I need to restore my computer without disc, what should I write in command prompt?
To access the System Restore Gui from command prompt you will need to type in rstrui.exe
OR
%Windir%\System32\rstrui.exe
Other Thoughts
If you are experiencing Boot issues you will need to install a boot manager. If your system is missing a file or a file is broken, you may need to replace that file with a working version that's compatible with your OS Version.
Aug 07, 2015 | Dell OptiPlex GX270 PC Desktop
Password reset on dell 518
Reset Your Windows Password Using the Command Prompt
1. Boot your computer using your Windows installation disc.
2. Wait for the setup files to load, and select your language. Click Next.
3. Click the Repair your computer link on the Install Windows screen.
4. Select the operating system to repair, and note the drive letter on which the OS is installed (it is probably C: or D:). Click Next.
5. Click Command Prompt at the bottom of the list of recovery tools.
Now you need to overwrite the Sticky Keys executable with the Command Prompt executable. Sticky Keys is an accessibility feature that allows a user to tap the Shift, Ctrl, Alt, or Windows key once to achieve the same effect as holding the key down. Ordinarily, tapping Shift five times activates Sticky Keys--but with this trick, you are going to make tapping Shift five times activate the Windows Command Prompt instead.
The instructions below use drive letter C: as an example. If your operating system is installed on another drive, replace C: with the appropriate drive letter.
1. In the Command Prompt window, type copy c:\windows\system32\sethc.exe c:\ and press Enter.
2. Type copy /y c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. At the login screen, tap Shift five times. The Command Prompt will pop up.
4. Type net user username password, replacing username with your username and password with a new password.
5. Exit the Command Prompt, and log in using your new password.
To prevent another user from exploiting the same trick to reset your password, you can restore Sticky Keys as follows:
1. Step through the instructions above to boot the PC using your Windows installation disc, open the recovery tools, and launch the Command Prompt.
2. Type copy /y c:\sethc.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. Pressing Shift five times will now activate Sticky Keys instead of the Command Prompt. Store your Windows installation disc in a secure location.
May 03, 2014 | Dell Inspiron 530 Desktop Computer
Granddaughter changed password on my computer unable to access anything help
copy d:\utilman.exe d:\windows\system32\utilman.exeYou can boot from your windows 7 disc and use the system recovery command prompt to change the password:
  1. Put windows 7 disc in computer and reboot
  2. When prompted to press any key to boot from CD/DVD, press a key such as the space bar
  3. Wait for the Install Windows screen to appear, there will be language options, press the "Next" button
  4. There will be an Install Now button and a couple links at the bottom of the window, press the "Repair Your Computer" link
  5. Wait for the "System Recovery Options" window, it will show you which drive windows is installed to (such as C: or D:) under the location column. Remember this letter and press the next button
  6. You will now have a list of options, press the "Command Prompt" link
  7. Assuming the drive letter you saw was D:, type these commands (if it was not D, then change to the letter you saw)
    1. copy d:\windows\system32\utilman.exe d:\
      1. Completion of this command will say 1 File(s) copied
    2. copy d:\windows\system32\cmd.exe d:\windows\system32\utilman.exe
      1. You will be prompted to overwrite, type Y and press enter
  8. Remove your windows 7 disc, close the command prompt window, and press the "Restart" button on the system recovery options screen
  9. Once your computer comes up to the log-in screen, there is a little button in the bottom left corner for ease of access options, press this button and a command prompt window will appear.
  10. In the command prompt type
    1. net user
      1. make note of your user name that is listed
    2. next type "net user" without the quotations followed by your username and whatever password you want.
  11. Close the command prompt window, then log in to your computer
To reverse the changes made to the file when in the windows repair command prompt:
  1. Insert your bootable Windows 7 media.
  2. Click the Next button.
  3. Click the Repair your computer link.
  4. Wait while Windows is found on your hard drive.
  5. Select Windows 7 and then click Next.
  6. Click on Command Prompt.
  7. Type the following command followed by enter
    1. copy d:\utilman.exe d:\windows\system32\utilman.exe
      1. If your drive letter was not d, then replace it with the correct one
      2. you will be prompted to overwrite, press Y and enter
  8. Remove your windows disc, close the command prompt, and press the restart button again
Oct 16, 2013 | Microsoft Windows 7 Home Premium 64BIT...
After downloading updates my paptop will not configure windows
Try this:
Windows XP
To start System Restore using the Command prompt, follow these steps:
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
    Windows 7:
    1. Start your computer in safe mode with command prompt. For more information, see Start your computer in safe mode.
    2. At the command prompt, type rstrui.exe, and then press ENTER. 18abb370-ac1e-4b6b-b663-e028a75bf05b_41.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Aug 19, 2012 | Sylvania G-Netbook
I need to know my ip adress and all that stuff?? help please
Inorder to find the ipaddress of your computer follow these steps,
1. Click on start? Go to All programs? Accessories?Command Prompt
2. You will find a black screen which is the Command prompt
3. In the command prompt you will find a blinking cursor , there you type in "ipconfig/all" (without cotes)and hit enter.
4. You will find ipaddress, subnet mask, default gateway , mac address/physical address and all other information of your comp.
Thanks in Advance!
With Regards,
Prema
Dec 31, 2010 | Computers & Internet
Restart my computer over
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
  4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
    For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
    For information about a specific command, type help commandname at the command prompt, and then press ENTER.
  6. To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Nov 25, 2008 | Computers & Internet
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Open Questions:
Avast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uKAvast customer service pHoNe #[++1888^499//5520;-] nUmBeR USA/uK
Oct 14, 2019 | Computers & Internet
Avast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR USAvast customer service pHoNe #[+1888^499//5520;-] nUmBeR US
Chachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone numberChachyou:: {{888}{499}{I833}} Avast customer care phone number
Computers & Internet Logo
32 people viewed this question
Ekse
Alun Cox
