Hi I have PC with motherboard AsRock
Hi I have PC with motherboard AsRock ConRoe945G-DVI. When I used WinXP everything was OK but two days ago I changed my system to new Windows7. It works much faster but there's one big problem - no support for front audio panel and I can't use my headphones with microphone (dual jacks connected to front panel). I tried different drivers but most of them even is not possible to install and other are even worst than this originally installed with Windows. If You now what to do and be kind to help me I will be gratefull otherwise I will have to go back to XP. Best regards - Szkrobi
    New Friend:
    Problem Solver:
  • 5 Answers
Operating System for windows 7 requirements a slightly different from the motherboard your using, why theirs no sound is because you need the mother board drivers to installed drivers Ive done that and it worked
Posted on Oct 24, 2010
SOURCE:
My asrock conroe945g-DVI has no sound at the front panel
has no sound at the front panel ? not sure i understand are you getting any sound or you dont have a sound icon
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
hope this helps
Oct 09, 2012 | Asrock ConRoe945G-DVI Motherboard
How to get audio driver ASRock ConRoe945G-DVI fsb1066
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
or you might download slimdrivers
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
note: it will find all of your outdated drivers
this is a free driver solutions
which will automatically search for and find the correct driver
or
http://download.cnet.com/2000-20_4.html
just type in what you want or need be specific you might have to try a few times to get it right
also
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope it helps
May 23, 2012 | Computers & Internet
Monitor says no video signal, not even from the onboard card. Do I need to get the DVI Graphics-SI card? I didn't get one with this refurbished board. I have tried PCI and PCI Express cards.
1) Monitor plugged into the VGA connector on the motherboard, (Rear Panel), you should get a display.
This is with the proper settings in BIOS.
Reset BIOS back to the factory default settings, and clear CMOS Error Codes.
Unplug the computer from power. (Monitor plugged into VGA connector on motherboard. No graphics card installed)
Press the Power On button in, and hold it in for a count of 5 seconds. (Count 1001, 1002, 1003, etc.)
Let go of the Power On button.
Do this procedure 2 more times.
Plug the computer back into power, wait 1 minute, turn the computer on.
If you get OnBoard graphics now is the time to install the drivers for the graphics card.
Then close all windows, turn the computer off, unplug from power.
OBSERVE Anti-Static Precautions and physically install the graphics card.
Still no?
Time to enter BIOS Setup, and see what graphics settings you have.
(When the post screen comes up press the F2 key)
On the main page use the Right Arrow key to highlight - Advanced - at the top of the screen.
Press the Enter key.
Use the Down Arrow key to highlight - Chipset Configuration
Initiate Graphics Driver should have - PCIE - to the right of it.
This stands for PCI Express. This is the factory default setting.
Internal Graphics Mode Select should have - Auto - to the right of it.
With it set to Auto;
The OnBoard graphics will be automatically disabled when a graphics card is installed.
The OnBoard graphics will be enabled when a graphics card is Not installed.
This is the download page from AsRock Support, for the User Manual for the AsRock ConRoe 945G DVI motherboard,
http://www.asrock.com/mb/manual.asp?Model=ConRoe945G-DVI
On this page click on Click Here to the right of User Manual, after you have chosen what country that is nearest yours.
Allow time for the PDF file to download. (Sometimes up to 30 seconds, and additional time may be needed to fully download the file)
I would also like to know what Power Supply you're using, and if you are sure beyond a doubt that it is a Good unit.
Regards,
joecoolvette
Jun 05, 2011 | Asrock ConRoe945G-DVI Motherboard
How to connect HDD LED & POWER LED & RESET LED & 2 others who is blue and whid & my SPEAKERS, can you help me here?
don't you have the book for the motherbd? Most motherboards tell you right on them wat connection goes where. look for them they should be in close vicinity of each other Usually.... HDD-Harddrive connection./.RST - Reset /pwr-- to switch ....etc....
Oct 16, 2009 | Asrock ConRoe945G-DVI Motherboard
ECS Motherboard GeForce6100SM-M
I disabled the onboard sound and fitted a cheap sound card. I shall not buy one of these motherboards again.
Jun 20, 2009 | Asrock ALiveNF7G-HD720P M/board, nVidia...
Error on mutlimedia controller
Try using Windows Update.
It usually has most audio drivers for a variety of boards.
That's the easiest route to go. If that doesn't work, let me know and i'll dig deeper.
Jun 15, 2009 | Asrock ConRoe945G-DVI Motherboard
Tis about REALTEK blahblah...i cannot see the volume tray icon
As you said you have formatted Drive C:, and installed XP SP3 and back again XP SP2.
Why don't you try formating the whole drive and reinstalling fresh Win XP SP2 and always choose NTFS partition only because all the features are supported in this partition.
Mar 18, 2009 | Asrock ALiveNF7G-HD720P M/board, nVidia...
Open Questions:
Amazon Prime pHoNe #{+1-85O-8I2-4OO9 how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon.This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 16, 2019 | Amazon Computers & Internet
Amazon Prime rEfUnD pHoNe #{+1-85O-8I2-4OO9 usa how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.
Computers & Internet Logo
Ekse
Alun Cox
