Question about Canon PIXMA MX700 All-In-One InkJet Printer
My Canon MX700 has an error code 5200. What does this mean and what should I do?
SOURCE:
drifterK
  • 4924 Answers
SOURCE: What does an error 5200 mean?
(1) With the printer turned on, unplug it
(2)Open the top and bring the ink cartridge holder to the middle
(3)Raise the gray bar and remove the print head assembly with the cartridges in it
(4) Lower the gray bar with the head missing and close the top with the head out
(5) Restore the power,wait til the printer wakes up
(6) It will tell you to put in the cartridges
(7) Restore the print head, close the top and the printer should resume working.....
it is a printer head error and some solved it that way ..after you do that it will resume the function and work ..
_________________
Posted on Jun 01, 2010
yooperbud
  • 8637 Answers
SOURCE: MX700 Canon Printer
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
komguy
  • 2306 Answers
SOURCE: Canon i860 error code 5200?
5200 is a printhead temperature error, defective printhead You need a new printhead,
QY6-0049-000 around $40.00
Posted on Aug 03, 2009
esound
  • 425 Answers
SOURCE: what does error code 5c00 in a canon mx700 printer
Hi, 5C00 is a purge unit error, the purge is the cleaning unit on the right where the print head parks when shut off. If paper or something is caught in there you get an error, also ink build-up can stop it as well, a damp Q-tip will clean some of the ink away, if it doesn't help you need a new purge assembly.
Hope it helps.
Thanks for using fixya..........
Posted on Nov 25, 2010
dhorsefield
  • 286 Answers
SOURCE: how to fix error code 5200 on canon printer MP258?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Posted on Feb 10, 2011
My printer canon mx700 has error 5200, what I have to do to fix it. Thanks.
This is a printhead overheat error but both the printhead and main logic board should be changed together and it would cost over 3/4 of the price of a new machine. So i would buy another machine rather than go for a repair.
Srri.
Jun 19, 2011 | Canon PIXMA MX700 All-In-One InkJet...
What does error code 5c00 in a canon mx700 printer mean?
Hope it helps.
Nov 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
_________________
Jun 01, 2010 | Canon PIXMA MX700 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Aug 03, 2009 | Office Equipment & Supplies
Error code 5100
5100 means either there is paper stopping the carriage from moving properly, or there is grease on the plastic strip behind the carriage. If you wipe off the grease with a Q-tip the error will go away.
Jun 24, 2009 | Canon PIXMA MX700 All-In-One InkJet...
MX700 Canon Printer
Dec 29, 2008 | Canon MX700 Office All-In-One InkJet...
Canon PIXMA MX700 All-In-One InkJet Printer Logo
1,088 people viewed this question
Clive
Clive
old marine
old marine
Ekse
