Question about Philips PTV100
Digits dropped while changing channel
My PTV100 has worked great for over ten years. Just recently it has started dropping digits when it attempts to change channel, either by remote or by prescheduled program. If I change the channel by remote, you can actually see the Tivo banner attempt to enter the correct digits, but when the DTV banner comes up, it shows only two of the three digits. Same thing with a prescheduled recording. When I watch a prerecorded show, at the beginning you can see where a digit is dropped. I have replaced the infrared emitters, and that didn't help. When I change the channel with the DTV remote, it works fine. This leads me to believe that the component inside the TIVO unit is causing the problem. Any ideas on how to solve this? I have lifetime service, so I'd really like to get this repaired!
  • 33 Answers
Make sure that you have the correct DTV box selected on the Tivo unit in the Guided Setup.
Make sure that the IR cables are directly in front of the IR eye on the Tivo.
Posted on Jul 05, 2010
I have Pioneer VSX-1027; the volume drops 3 digits every three minutes and it keeps dropping three digits every three minutes until it reaches to the minimum..! Why does this happen? How to fix it?
It is a problem with the temp sensor circuit. The unit thinks it is getting hot, so it is trying to turn the volume down to avoid overheating. You either has a bad thermal resistor on the amp board, or you need to change the cpu board. Best to have it looked at by a pro.
Sep 26, 2016 | Pioneer Audio Players & Recorders
Digitrex remote control codes
0382,0829,0119,0963,0000 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 14, 2013 | Televison & Video
Bought a saw 61 sn 0150063 wanted to know what year it was made and what cc it is thank you
The 61 was was in production from approx 1978 through to 2009 as you can see this was a long run for one model, it was without a doubt a very good machine, the early 61 had a white top cover, it then went to a grey top cover, and the later machine had a orange top cover, there were a number of changes during these years, however it did remain the basic machine it started with, it was 61cc and was offered in the UK with 13/15/18/20" bar lenghts, the ser no.s normally had 9 digits, the first number was the year of manufacture in a ten year rotation, so 0 could be 1980 or 1990, at the year 2000 the first two digits was the year, so 00 was 2000, 01 was 2001 and so on, the following two digits was the week number, hope this helps.
Jun 11, 2011 | Husqvarna Garden
I just dropped my phone and now its asking me for my puk code what do i do
This is really weird. The PUK (Pin Unblock Key) is a code stored on the SIM card and is normally requested after three unsuccessful attempts to enter the PIN (personal identification number, the number you use to authenticate to the SIM card after switching off the phone).
You should have received a PUK together with the SIM card; its usually a longer code, six to eight digits.
Beware, if you enter a wrong PUK ten times in a row, the SIM will become blocked permanently and unrecoverable. You would need a new SIM card.
If you cannot locate your PUK, you should contact your phone service provider.
Feb 11, 2010 | Sony Ericsson W910i Cellular Phone
I dropped my ipod- key now frozen
Have you already attempted to reset the iPod?
If not you will want to attempt that as your first step towards resolving this issue.
To do so you will need to simply press and hold both the center and menu buttons for at least ten seconds or until the apple icon appears on the screen.
If this does not resolve your issue please do let me know.
Nov 11, 2009 | Apple iPod nano
Enter channel number of double digits?
Are you being serious? Are there numbers on the remote? press 02 for channel two press 08 for channel eight press 10 for channel ten all the way up to 99 then back again.
May 30, 2009 | Hitachi CLU-5713TSI Remote Control
Netgear WGR614 v6 router drops connection
Hi, what ISP are you using (aol,tiscali...?), and how are you connecting to the router? Wired or wireless? I had similar problems with mine, it wouldn't connect or would drop connection, or loose all the settings. I updated the firmware to the latest from here:-
http://kbserver.netgear.com/products/WGR614v6.asp
Be sure this is the correct model as firmware differes from model to model.
Then I had to manually configure my ISP settings etc. Or you may have software from your ISP which configures for you.
Hope this helps.
Jan 22, 2009 | NetGear WGR614 Wireless Router
Volume drop and have to hit input hard to get it to start working
Re-solder input jack connection to the board. Sounds like cold solder joints.
Dec 11, 2008 | Mackie 1604 Vlz3 16 Channel Mixer
Trouble with outdoor photos with my camera (indoors seems to work great)
Hi. please check the ISO setting. It might have been changed. let me know, I have the same camera, will check more on it for you. good luck.
Aug 10, 2008 | Fuji FinePix S7000 Digital Camera
Programming bc147xlt uniden scanner
to program the uniden bc147xlt use the manual button to select channel you want to program. punch in the desired 6 digit frequency then press E, press review to check that frequency was input correctly then use the manual button to go to next channel for programming.MAKE SURE WHEN ENTERING FREQUENCY YOU INPUT THE (.) AFTER THE FIRST 3 DIGITS FOR EXAMPLE GO TO CHANNEL 1 PRESS 149.220 E AND YOU should have no problem programming . hope this is helpful
Dec 11, 2007 | Office Equipment & Supplies
Philips PTV100 Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
