Question about Gigabyte GA-8PE800 PRO Motherboard
I need lan driver for ga-8pe800 - Gigabyte GA-8PE800 PRO Motherboard
    New Friend:
    Problem Solver:
  • 5 Answers
Go to Google search and download the driver ga-8pe800 you will get it on the net!!!
Posted on Oct 24, 2010
SOURCE:
Mm, my PC didn't turn on and I open de case and I coul see that it had a lot of dust and I cleaned and then It turn on normally. But when I turn on the Pc doesn't detect the netword card, so I can't...
If you have an OEM network card that you installed yourself, then we'll need it's make and model.
If you're referring to the onboard LAN functionality built into that motherboard, it's a Realtek 8201BL PHY
If you have another computer that you can download the drivers on, and then bring them over to this one by usb, you can download the drivers for your motherboard's built in network port from the website below:
http://www.centuso.com/realtek-8201bl-phy
Mar 04, 2011 | Gigabyte 845pe (GA-8PE800PRO-R)...
I dont have sound on my computer @ the moment, would somebody help me? my mother board is p4 titan ga 8pe800.. plz... tnx much!
Go to this link http://kickasstorrents.com/
Search universal xp drivers CD
Download CD using torrent download CD
To install drivers go to my computer properties
Click on device manager
Install drivers using update device driver...
Browse the downloaded drivers in the given window..
After installation restart your system once...
Dec 05, 2010 | Intel Computers & Internet
What RAM to use. I would like to use 1600mhz RAM but am not sure what would be the best to use. I am installing 12gb of ram. I will install 6gb now and another 6gb later.
Memory  6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory (Note 1)
 Dual/3 channel memory architecture
 Support for DDR3 2100/1333/1066/800 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
and
Memory support list Date Subject 2005/05/12 Recommended memory module list for GA-8I915P Duo Pro ...More 2005/03/01 Recommended memory module list for GA-K8VT800 (Rev 2.0) ...More 2005/02/21 Recommended memory module list for GA-K8NF-9 ...More 2004/12/13 Recommended memory module list for 8I845GE-RZ/C ...More 2004/10/15 Recommended memory module list for GA-8TRX330-L ...More 2004/09/02 Recommended memory module list for GA-8TRS350MT ...More 2004/03/22 DDR400 support list for FSB800 CPU support - GA-8IE2004P \ 8IE2004P-L ...More 2003/12/23 PC3200(DDR400) Recommended module list for GA-8TRS300M ...More 2003/11/28 DDR400 support list for FSB800 CPU support - GA-8PE800 \ 8PE800-L ...More 2003/10/16 Recommended DDR400 (PC3200), DDR434 and DDR466 memory modules for GA-SINXP1394 ...More 2003/10/02 Recommended DDR200/266/333/400/466 Memory support list for GA-K8NNXP ...More 2003/07/23 Recommended DDR333(PC2700) memory modules for GA-8S650GXM-P (-C) ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SQ800 Ultra and 8SQ800 ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SG800 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-8SG667 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-7VAXP Ultra, GA-7VAXP, GA-7VAX, and GA-7VA ...More
Dec 27, 2009 | Gigabyte GA-EX58-UD5 Motherboard
Hi Mike re: GA-8PE800 M./B. what does the BGA
Depending on what you're doing, it actually has a number of different meanings for different fields. Here's a list of Acronyms for it.
BGA Acronym list.
Oct 17, 2009 | Microsoft Windows XP Professional
GA-8PE800 MOTHERBOARD DRIVER
Hi, I'm listing a link below to the GIGABYTE site for your motherboard. Download and install the drivers for your operating system there. If this helps, please rate this answer. Thanks! Hal
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1619
Jun 11, 2009 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
GA-8pe800 pro and kvr333x64c25 memory problem
the 1g is defective return it and get a replcement
Mar 28, 2009 | Gigabyte GA-8PE800 PRO Motherboard
Where can I buy a GA-8PE800 Pro motherboard?
Sorry Jack, I exhausted most of my resources and did not come up with one. This mobo will be a big pain to find. I would say buy a new board and unforunately reinstall your operating system. I know it's a pain, but I don't think you're going to find this board without some extreme luck.
What you could do, is find a similar board with the same north and south bridge, same chipset. This will allow you to not have to reinstall your OS.
It is possible to keep your current data set and still install a different motherboard. It requires disabling all plug'n'play support built into the OS before swapping the board. Then you install the new set of chipset drivers for the new board. I have made it work before, but its certainly not the cleanest way to do this, as you well know.
Sorry for not being anymore help. I can usually find old mobo's fairly easily, but this one must be a needle in a haystack.
Jan 17, 2009 | Gigabyte GA-8PE800 PRO Motherboard
Iv just been given a gigabyte GA-8PE800 motherboard
Gigabyte actually has a very good website. I pasted a link below to the CPU support list.
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1619
As far as what would be the best to buy I would say the closest to the top that you can afford ignoring the P4-Extreme CPUs.
Dec 09, 2008 | Gigabyte GA-8PE800 PRO Motherboard
GA-8PE800
re seat your memory and clean them.
Sep 15, 2007 | Gigabyte GA-8PE800 PRO Motherboard
Gigabyte GA-8PE800 PRO Motherboard Logo
183 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
