Question about Fedders AED24E7F Wall/Window Air Conditioner
My air conditioner doesn't blow out any air.
When you turn the air conditioner on you can here the compressor running but there is no air coming out and the fan is not running. The compressor sounds weak sometimes. Or what I think is the compressor. Same problem. Window unit. Sounds like the compressor works but not the fan. I followed the manufacturer's troubleshooting guide that said to unplug it and plug it back in and then to try resetting the circuit breaker. Unplugging it didn't do anything but resetting the circuit breaker did. The fan sounded like it kicked in and was about to run then made a pop sound and I could smell a burning smell. I unplugged it from the wall. What do you think?
  • Anonymous Aug 11, 2008
    smelt something burning this morning, a/c sounds weak, shut off. I waited and turned it back on after a while, it does not blow now.
4 Suggested Answers
SOURCE: My air conditioner doesn't blow out any air.
If this is a central air unit & you\'re talking about the fan on the outide of the house the problem may be that you are only getting 110 volts to the system side of the contactor. If you have the tools & know how you can check this yourself. If not, time to call a repairman.
Posted on Jun 01, 2007
  • 66 Answers
SOURCE: Air conditioner will not keep running
Any one with a window; these units must be cleaned at least yearly.First off,there is a filter in the front below where the cold air comes out,inside the intake grill(where the room air goes back into the unit.) it should slide out. Second the unit has another coil at the rear of the unit.The rear coil is hard to clean, but is possible.Check if warm air is going out at the rear.If not unit housing must come off to clean rear coil properly.After a year ,or two this problem will very probably blow the compressor.You should be able to call a few A.C. companies and see if they clean windows A.C. units.
Posted on Feb 18, 2010
239gatorac
  • 1555 Answers
Is this the outdoor fan or blowet/indoor fan you are referring to? Either way, you must make sure the capacitors are good and then verify the motors are getting high and low voltage.
Posted on May 07, 2017
My ac doesn't blow cold
Can you hear the compressor starting? If so, suspect broken pipework and loss of refrigerant. If not, suspect loose wire to compressor or thermostat
Apr 19, 2012 | Dometic Rooftop RV Air Conditioner
Ive owned the 10x6c for 2 years never used it because of my wiring doesn't have a ground,,let my neighbor borrow it and it doesn't blow cool air I hear the compressor turn on but no cool air?
If the compressor is coming on and the air is not cold, it could be that the freon has leaked out. Easiest way to check for no freon is to take the cover off the unit and run it in cool. The high side which is the smaller line coming into the top of the compressor should be hot, and the low side which is the large line coming off the side of the compressor should be cold when the compressor is running. If there is no temperature difference between the high side and low side tubing, you have no freon. Also check for oil residue once you have the cover off. If you spot oil, you had a leak and have no freon.
Aug 14, 2011 | Haier hwr10xc6 Air Conditioner
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
Danby DB98-26786A window air conditioner will start up and blow cold air..frost forms on the tubes..after a few minutes the frost disappears and the compressor shuts off .. the fan still blows; but no...
heatman101
Jul 23, 2011 | Danby Heating & Cooling
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
I can hear the air compressor come on but doesn't blow cold
If it is blowing air and the compressor is running you are low on freon more than likely. make sure the fan on the unit is also running it helps it get rid of heat on the external coils. if all fans are running and the compressor is running it is low on freon.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
Air conditioner blowing only warm air
possibly have a capacitor out on the compressor side of the a/c Since the unit works and its only blowing air the compressor isn't kicking in. The capacitor boosts the compressor to activate the compressor. I would have the capacitor to the compressor replaced first before going any further.
Good luck on your repair
Dave
Oct 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Air conditioner is set on cool & furnace is turning on
probably your compressor not running or the air con is out of Refrigerant.
Jun 06, 2009 | Intertherm P3RA-048K Air Conditioner
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
AC keeps blowing fuses
Fuses are a protection device and I guess that this is for the condenser section and compressor. If they blow right now when it is turned on would indicate that there is a short in the wiring or motor or compressor. If it trys to start and the outside fan starts and the compressor just humms and blows fuse, you have a locked compressor. Might check run capacitor or install a hard start kit and see if it will brake it loose, if not bad compressor
May 31, 2008 | Ruud UBHC Air Conditioner
Fedders AED24E7F Wall/Window Air Conditioner Logo
429 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
