How to wire 3 phase plug ? and L1,L2,L3 have to be in an order ?
    Guru:
  • 1,524 Answers
Yes they must be in order or unit will not run properly.
Posted on Oct 24, 2010
SOURCE:
Previously hard wired. How do I connect a power cord?
It doesn't really matter which wire goes to L1 L2 or L3. All that can happen is it will run in the wrong direction. If it does just interchange any 2 of the L1 to L3 connections and this will reverse the motor.
Dec 08, 2015 | Hobart D300 Stand Mixer
How do i rewire a broomwade 3 phase compressor 1970
Rewire for ?? High voltage motor wiring is L1-T1, L2-T2, L3-T3, T4-T7, T5-T8, T6-T9. Low voltage is L1-T1-T4, L2-T2-T5, L3-T3-T6. The motor protection overloads will need to be sized accordingly, to the motor's FLA ( full load amps) for the voltage used. The control needs to be looked at also, if there is a control transformer, the transformer needs to be wired or repaced for the new supply power voltage used.
Mar 12, 2015 | Air Tools & Compressors
I need to wire up a 3 phase compresser motor, 9 wires wired 480, to change to 240 volt hookup. right now it is wired 3 motor wires to each hot, no nameplate or wiring diagram.
Please verify the existing connections to determine if they fit the "High Voltage" configuration listed below. If they do (and they should), the "Low Voltage" configuration below is then correct for 240.
Jaypug
Low voltage ...
L1---1--6--7
L2---2--4--8
L3---3--5--9
High voltage ...
L1---1 4--7
L2---2 5--8
L3---3 6--9
Dec 04, 2013 | Gb Electrical 100 Amp GE Load Center
We have IR SSR 150HP compressor, where when starting alarm display "check motor rotation" we already change the phase L1, L2, L3 but this alarm still appear. what should we do?
to change rotaion on a three phase motor just which 2 leads.
Change L1 to the wire now on L2 and take the wire on L2 and move it to L1. the rotation will now change. or L2 and L3... just two wires
Nov 24, 2010 | Ingersoll Rand Stationary Air Cooled...
Whomever; I am confused as far as what does f1, f2, f3, mean on settings, and is the proper one to use? thank you.
I am confused as U DID YOU MEAN L1 L2 L3 SOUNDS LIKE 3 PHASE, IF SO TO CHANGE ROTATION JUST SWAP ANY 2 WIRES. IF NOT L1 IS A LINE L2 IS A LINE A. 3 MAY BE A 110 220 SETTING .. NEED MORE INFO
Aug 18, 2010 | Pool & Spa
Need to rewire from 480 to 240 need coolant pump diagram for colchester # 348337 3 phase motor
Assuming that the motor has 9 leads and the wire numbers are still on the wires, for 240 volt 3 phase connections:
Connect T1, T6, and T7 together with L1 (A phase)
Connect T2, T4, and T8 together with L2 (B phase)
Connect T3, T5, and T9 together with L3 (C phase)
If you're not sure which of the incoming wires from the supply are L1, L2, and L3, just pick one. If the rotation is wrong just swap any 2 (TWO) phase wires.
Jun 22, 2010 | Measuring Tools & Sensors
Need wiring diagram for 3 phase electric motor
motor leads on a three phase are T1, T2, T3, T4, T5, T6, T7, T8, T9. for high voltage [480] L1 to T1, L2 to T2, L3 to T3, connect together and tape - T4-T7, T5-T8, T6-T9. For LOW voltage [240] L1 to T1 & T7 & tape, L2 to T2-T8 & tape, L3 to T3 & T9 & tape. T4-T5-T6 together and tape.
Oct 20, 2009 | Saws
How to wire a 3 phace 5 hp baldor motor
the neutral or white is not used. if the fourth wire is a ground then it goes to the motor frame. if it is a dual voltage motor then here is the wiring: for 240 volt 3 phase connect 4-5-6 together and tape, 3-9 goes on L1, 2-8 together goes on L2, 1-7 together goes on L3. To reverse direction swap any two line wires. For 480 volts 3 phase: L1 goes on T1, L2 goes on T2, L3 goes on T3. Connect together T6-T9 and tape, connect T5-T8 and tape, connect T4-T7 and tape. again to reverse direction swap two line wires.
Oct 14, 2009 | Baldor 115v,1ph, 3,600rpm 7" 1/2hpbnch...
Wrong direction of rotation
swap any two leads L1 to L3 this will change rotation hope this helps a common color code is brown orange yellow in that order known as BOY at power feed you can change the wires at the disconnect load or motor side
Jan 24, 2009 | Air Tools & Compressors
Heating & Cooling Logo
162 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
