Question about Goodman GMS90703BXA Heater
Goodman GMP100-4 FAN STAY ON AFTER CYCLE REACHES RIGHT TEMP.
  • lgaither Jun 12, 2008
    it was the circuit board
    thank you all for your help in this matter
    l gaither
  • 1,420 Answers
You have either a misadjusted fan switch or a bad fan relay. Or your thermostat has a fan switch on it that may be in the "On" position. Check the thermostat first, then if that is not the case, you will need to call your technician.
Posted on Jun 10, 2008
We have a 2008 Dodge Grand Caravan. My question is: when the engine is running, does the radiator fan run constantly or intermittently?
electric fans start to operate when the coolant temp reaches around 88 c and will run continuously while the coolant is above that temp
if you have ac then there is a fan that cools the condenser in front of the radiator and that will cycle according to the ac compressor cycles
Jun 02, 2017 | Dodge Cars & Trucks
SS w/3.8l engine. What would cause the first electric fan not run but when temp rises the second fan will come on?
The coolant fan should kick on when temp reaches 192 degrees. Have you changed your thermostat? The 2nd fan is for the a/c. If car is running hot, it's probably thermostat or cooling fan
Apr 05, 2016 | 2001 Chevrolet Monte Carlo
Lincoln 2002 ls overheating
the fan will turn on when the engine temp reaches a set temperature and will only turn off when the engine drops below a certain temp and on the highway running hard it may stay on longer
Oct 01, 2012 | 2002 Lincoln LS
Heater fan suddenly stopped working
Please understand that the fan may stay on or off for several minutes even after the engine is shut down and the keys are removed!!! There is a sensor which detects heat coming from the engine. This same fan will stay on until the system reaches a lower temp. You may always reset your vehicle programming for this same device by removing the red lead to your battery and then replacing it after several seconds. Please follow up with a reply if this does not help your situation.
Jan 20, 2011 | 2006 Hummer H3
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Is my fan supposed to remain on after I turn off the car
The fan will stay on until the motor temperature reaches a low enough temp. This is to prevent damage. As long as it does not stay on for more than a few minutes it is normal
Jul 26, 2010 | 2008 Saturn Sky
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
The fans dont start til temp reaches redline on temp gauge.
Thermostat and Coolant Temp Sensor is What I Recomend Replacing on this Vehicle
Aug 12, 2009 | 1999 Chevrolet Lumina
Goodman GMS90703BXA Heater Logo
535 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
