Question about GE Microwave Ovens
JVM1640CJ03 DOOR IS BROKEN - GE Microwave Ovens
  • 525 Answers
Follow the link below and you can find the part(s) that relate to the door issue.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Re-post me if you need any more assistance.
Thank you,
Dave E. (Illeagle)
Posted on Jun 08, 2008
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
Oct 27, 2013 | Microwave Ovens
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
Oct 26, 2013 | Sanyo Microwave Ovens
Door wont open
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aSkJuabC
Jul 29, 2013 | Haier Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
The door doesn't open
please follow the instruction and fix it. God bless you
May 28, 2013 | Cuisinart Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Ge spacemaker microwave jvm1640cj03 stopped heating. interior always clean. light, timer etc working.
If it stops heating and the other parts of the oven still work, the problem is with the magnetron circuit. If it makes a loud buzzing noise when you try to heat the food, then the magnetron has shorted out. The replacement cost for the magnetron is almost as much as a new oven, so it does not make sense to have it fixed. Sorry.
Apr 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Broken door opener button
sounds like the door latch hook is broken you will have to seek a repair man for this
Feb 12, 2010 | Whirlpool GT4185SK Microwave Oven
Model JVM1640CJ03
If the turntable tray is positioned and seated properly, it is probably a failing turntable motor. You can find usually helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 09, 2007 | GE JVM1640 Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
