Question about LG Dryers
The dryer starts but does not heat at all - LG Dryers
  • LG Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 28, 2010
SOURCE:
Dryer not heating
sounds like a faulty pc board starts heating and then their is no power going from board have come across loads of times
Apr 09, 2014 | Maytag Neptune MDG5500AW Gas Dryer
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
My kenmore elite electric dryer inconsistantly starts to heat and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Dryer won't heat up. It starts to heat then goes off
heatman101
May 21, 2010 | Kenmore 63942 Dryer
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Kenmore gas Dryer Heats at start then stops heating
Usually problem like this with electrical solenoids located on the top of gas valve inside the dryer. They need to be replace.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 08, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
37 people viewed this question
Top LG Dryers Experts
jimorris77
John Tripp
John Tripp
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
