Question about Hardware & Accessories
I've lost the instructions for a TRAC Immersion Heater Timer Model CPI 24/7. How do I set it? many thanks Sue
SOURCE:
  • 131 Answers
SOURCE: Where can i get a user guide/instruction leaflet
http://www.greenbrook.co.uk/pdf/T106-C.pdf
AndystUK
Posted on Aug 30, 2009
SOURCE: setting GE Plug in mechanical timer 24 Hr Model
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Posted on Dec 18, 2009
  • 16 Answers
SOURCE: Lost setting instructions for Intermatic timer
I have located a site which has the instructions for your timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb800r.ashx
I located this while searching for an image of your model timer
Posted on Feb 18, 2010
Testimonial: "Great....thanks...."
SOURCE: Need instructions for T.R.A.C. dial hot water
I thought I knew every water heater timer possible.
Never heard of T.R.A.C.
Is that a European timer?
Here's what to do. Set the pins one direction or the other. Start with cool water in tank, so it will turn on for sure when power is applied. Turn on power. Put your ear against water heater. Listen for bubbly-fizzing sound that tells you water heater is on.
Check label on side of tank to see voltage & wattage of tank. Watt rating for dual element tanks is same as element wattage, since only one element is ON at a time. Generally, 240V electric tanks are 3500, 4500, and 5500 watts. That is 16 amps, 21 amps and 23 amps. Make sure your timer has amp rating to match water heater.
Posted on Oct 06, 2010
shunt311
  • 34 Answers
SOURCE: Model #15119 GE plug in
Hi, here is the manual for your timer.
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15119-Manual-eng.pdf
You need the adobe reader to view PDF file's if you dont have it here is the link.
http://get.adobe.com/reader/
Good luck (",)
Posted on Jan 07, 2011
Need instructions for grasslin 16 amp immersion heater timer
https://fauroanofi.files.wordpress.com/2015/03/grasslin-immersion-heater-timer-manual.pdf
Apr 21, 2015 | Hardware & Accessories
HOW TO RESET A KINGSHIELD IMMERSION HEATER TIMERundefined
http://waterheatertimer.org/Woods-timers-and-manuals.html#PB
Identify timer among timer modules shown on link above
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 02, 2014 | Hardware & Accessories
My Eurosonic 7 day programmable timer doesn't activate. I've lost the instructions, are they available?
1) Eurosonic appears to analog timer:
http://waterheatertimer.org/How-to-set-timers.html
2) There is new series of digital timers from china, also sold as Eurosonic:
Copy following link for possible manual. Always reset digital timers before programming.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
3) Add a comment March 2013 and describe timer in detail
Mar 10, 2013 | Hardware & Accessories
Hi experts! I've moved into a new Flat but there wasn't a manual left for the immersion heater timer. At the moment I'm leaving it on all the time which no doubt will start to cost more money than...
Mikey Mike, I think I may have found a link that you can find the Owners Manual you're looking for. You'll need to pick one that looks like yours (since you don't have a model #), click on it and after it takes you to another page, browser back and look at the top right corner and you'll see a highlighted technical link. Click on it and it will take you to the Owners Manual for that particular model.
By the way, your timer is manufactured under the name TRAC Immersion timer.
I hope this helps, because finding things in the UK ain't easy, for this good ol' boy from the US. If does, please leave me a good rating. Thanks!
http://www.tlc-direct.co.uk/Manufacturers/Trac/Timers_Wired/index.html
Mar 24, 2011 | Heating & Cooling
I have the imm24 timer and would like a better quality timer which one will work
Imm24 timer is 230V 3500amp flush-mount hard-wire 24-hour mechanical-dial immersion heater timer
Following page shows imm24 timer and other brands of immersion timers
http://cpc.farnell.com/1/1/51662-immersion-heater-controller-box-imm24-apt.html
Prices are in Euros and Pounds, so I don't know distribution range of product.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 03, 2011 | Hardware & Accessories
Where can I buy/get the instructions for a T.R.A.C. TC CP124 immersion heater timer?
Probably too late, but may help someone else. Sorry about the poor quality; https://www.dropbox.com/s/ib2hyco004qdtcn/TRAC%20CP124.pdf
Oct 31, 2010 | Kitchen Appliances - Others
Hardware & Accessories Logo
808 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
