My York Diamond 80 furnace will not ignite? The thermostat does send a signal to the furnace beginning the cycle with inducer starting and contiuing to run. The igniter will not heat up. I have tested the air pressure switch and ignitor swapping on a second unit is the house. All are good. The unit solution light is blinking 3 time indicating open pressure switch did not close. Is there a way to test the inducer to determine if creating necessary pressure?
5 Suggested Answers
SOURCE:
  • 92 Answers
SOURCE: Furnace keeps shutting down after lights
time to call service guy you are cycling on a saftey which means somethings not right in ignition circuit the only thing i would tell a untrained person to try is cleaning the flame rod which is part of the pilot assembly it is a metal rod that gives small electric current to ignition device confirming that you have a pilot lite you can lightly sand with sand cloth
Posted on Apr 15, 2009
  • 116 Answers
SOURCE: Furnace Filter recommendation
measure the out side to outside most likley 20x20x1 or 20x25x1 depends on the size of unit
Posted on May 16, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: HEIL 80% furnace T-STAT calls for heat, Inducer
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Nov 03, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: York Diamond 80 Furnace: blows cold air after
There may be more than 1 limit switch. Look at the wiring diagram and follow it to all switches. Or jump out the complete circuit.
Posted on Jan 21, 2010
York diamond 80 furnace
Each step in the process must be satisfied in order to go to the next one. Yes, make sure the "Hot Surface Igniter" is good. Is the venter motor reaching full speed to close the air switch? Did you check the end of the vent pipe that nothing is obstructing it - like a bird.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Apr 01, 2017 | Heating & Cooling
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
Does a york diamond 80 furnace have a pilot light?
There is a diagnostic code flashed from a window in front panel of the furnace. What is it? From your description, I would bet on the ignitor as faulty. The vidoe shows this repair. Don't remove elements and sand them as this fixer did. it is destructive in many cases. York Diamond 80 furnace troubleshooting won start won light flame sensor...
Mar 08, 2018 | Heating & Cooling
York diamond 80 fan starts running blowing cold air before furnace ignites..replaced thermostat
OK so you replaced the Thermostat huh? OK well then did you also replace the Thermistor Temperature Sensor? or whatever is used? As often it's BOTH, also check the wiring from the sensor to the host, in any event if it's NOT that then all it can be is the controller board, most likely the Micro? Check any and all sensors first though.. try to get a service manual too, it's hard without one?
Oct 20, 2011 | York Furnace Draft Inducer Blower Fasco #...
Our York Diamond 80 is not operating. I pulled the front panel and followed the start-up procedure. The blower comes on for about 20 seconds during which time, i can smell gas but there is not ignition of...
Had the same problem. The heat quit during the night leaving the fan blowing cold air only. Ah, Looked online yesterday at all that came up in various forums. Not once did I see the suggestion "Replace the Glow Plug" which I suspect is common in a 6+ yr old "York Diamond 80" - Not very helpful, guys...Cost for part was about $22. I paid a handy local another $40 to diagnose, locate & purchase the plug, remove & replace the plug. If you want to continue to attract advertising to these forums I think you need to turn down the obfuscation & engage your experience & be a lot more forthcoming with known common solutions instead of the whirling around all the "it could be's" Seems to me to be an effort to intentionally withhold and not to be too helpful while pretending to be offering a worthy place for the homeowner to discover that you guys charge gravy flat fees for things anyone with a common set of tools & a bit of honest guidance could do himself. I know, it's a dog-eat-dog world & baby needs new shoes but unless we all start actually helping each other this world is gonna keep getting worse for yours and my kids futures. Self-interest has got to be seen in proper perspective, not from the view of The Law of The Jungle mentality that has taken us to the brink of inhumanity. It was NOT this way in "The Greatest Generation" my Fathers world. In that world The Bastards were the exception not the RULE!
Mar 11, 2010 | Heating & Cooling
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
Gas furnace
Hi check out the pressure switch clean the air filter and check out the fan control see if this is clean
Feb 16, 2010 | York Furnace Draft Inducer Blower Fasco #...
My york diamond 80 fans come on and I can see the glow then it fires before cutting off after 5 seconds, is this a bad ignitor
Bad or dirty flame rod or burners.
Jan 09, 2010 | Heating & Cooling
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
Heating & Cooling Logo
280 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
