Question about Nintendo DS Lite Console
Ds Lite bottom screen flashes then shuts down
If you had a bad top or bottom screen wouldn't the nintendo stay powered up if you had them disconnected.Wouldn't this tell you if one of the screens were defective?
Thanks,Tom
I am having the same problem, how do you fix it?
Posted on Nov 19, 2009
  • 19 Answers
Not necessarily. When the cable to my top screen became partially torn, it prevented the DS from powering up. Instead, the green light briefly lit up and then went out and the machine stayed off. I can only presume that feedback is required from the screen. As for the bottom screen, I'm unsure of how the DS behaves when the screen or cable is damaged.
Hope this helps.
Posted on Jun 07, 2008
  • Gimpoid Jun 07, 2008
    Incidentally, when my top screen's cable was damaged, the bottom screen did flash white briefly at switch on. The way the top screen's flex cable passes through the hinge on the DS means it's subject to stress and eventual damage, and so is the most likely culprit. Not a fun job to dismantle and check, but it can prove the cause of the fault. Another thing to remember is that the cable can become dislodged from its connector on the PCB. It can also appear to be in the connector, but in fact isn't far enough into it to make electrical contact, so reseating it properly is necessary just in case.
My son's DS lite stopped working while he was playing. Tried charging...no good. Bought new battery...no good. When turning on the charge light turns green then the bottom screen flashes white (like it...
Hello there! First of all let me tell you that your nintendo ds can be repaired and it is not trash... what you need is to get the bottom screen to be repaired ....you can do it sending it to the nintendo repair shop or by doing it yourself by following this youtube guide http://www.youtube.com/user/nintendorepair.
Sep 21, 2011 | Nintendo DS Lite Console
Screen goes white on power on and then shuts down power
This is basically due to a faulty screen. Depending on which screen flashes white when you first turn the DS on, this tells you which screen is faulty. If the bottom screen flashes then it is the top screen that is faulty. If the top screen flashes then it is the bottom screen that is faulty. Screens are fairly easy to fit although the top screen is the harder out of the two, you can buy them off of ebay for around £10 and if you google DS screen replacement there are some good guides out there showing you how to do it.
Hope this helps
Jan 29, 2011 | Nintendo DS Lite Console
Ds lite comes on the top screen flashes then it switches off
It could also be a bad top screen due to a bad ribbon cable. If your hinge is cracked it could cause damage to the ribbon cable that passes through it, this shorts out the top screen and will shut the DS down
Jul 08, 2010 | Nintendo DS Lite Console
My ds will not turn on
It sounds like one of you're screens has broken. What you have discribed is generally what happens one either the top or bottom LCD screen has broken.
If it is the top screen the bottom screen will flash for 1/2 a second and the DS turns off.
If it is the bottom screen the DS should still turn on but with no reaction from the screens. (the Ds will shut down immediatley after turning on)
Sep 17, 2009 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
Nintendo DS Lite problem
I THINK UR DS IS SCREWED UP BUT THE SHELL DIDNT DO ANYTHING
Jul 28, 2008 | Nintendo DS Lite Console
Fuse location on nintendo ds lite
Bottom screen flashing and the unit shutting down is more like a broken top screen or ribbon problem.
The fuse problems usually blink the amber light in your DS each time you connect the charger.
And I am sure you will find a guide looking in google for it, just as I did and there are plenty.
Jul 01, 2008 | Nintendo DS Lite Console
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Jun 26, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
558 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
