Question about RCA F36665 36" TV
RCA television turns itself on every day same time
I have an 8yr old RCA tube type TV model F36665. Every morning about the same time, it turns itself on. There is no internal timer for this, only a sleep timer. I've unplugged it for several days and plugged it in and it still does it. Can it be associated with a power surge of some sort? It just started happening.
techman
  • 3130 Answers
SOURCE: tv will not power up
no reset button ,sorry. The problem you describe is pretty common with this model as its a fault in the horizontal drive circuit or in the main power supply and without the proper service manual as well as the prober tools and equipment this set its not gonna get fixed. there are no panels or user changable boards as it is a solid state set. ptscorp.com could repair this board or exchange it with a referbished board but it would still requir some adjustment that a user may not be able to handle. time to call the pro.. Sorry couldnet help ya more.. Good Luck.
Posted on May 24, 2006
  • 1694 Answers
SOURCE: RCA 32V420T 32" TV
reset by unplugging AC cord for few minutes, a few hours,or overnight,if needed.Let me know if that does not work.T.
Posted on Oct 09, 2007
  • 1153 Answers
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Posted on Jan 08, 2008
mjap
  • 107 Answers
SOURCE: RCA F27227EM 27''
maybe an IC is mulfunctioning around the power suply. a four leg IC, sometimes its white or gray, try to change it.
Posted on Jan 19, 2008
  • 135 Answers
SOURCE: TV turns on & off
Hi there!
Exterior equipment attached to a standard tv cannot cause the set to switch on/off by itself.
I think you may have a power supply fault or else loose solder connections on the board, hence the "warming up" intro before the fault shows itself.
My suggestion would be a service technician if you are not familiar with electronics or TV's. Regards, JUS004
Posted on Mar 24, 2008
I have my rca model f36665 hooked up strait from the wall to the tv and I can't get it to find the channels. do I have to have a cable box?
First if cable I presume you have entered the menu and selected cable.
Another possible reason is the tuner/s in this set are bad---hook a DVD or something to one of the rear inputs and see if set works.
If set works that way and tuner turns out to be bad you can with a box with av cable out connections on back just go into a rear input and bypass the tuner--leave set on that input and change channels with the box.
Let me know if you have questions and what you find---usually on this set if no signal---"unusable signal" will appear on screen if no signal.
Mar 20, 2012 | RCA F36665 36" TV
Need to get the weight of a RCA Model f36665 36" tube tv
Sorry I can't give you the exact weight. My service literature has everything but dimensions and weights. But Amazon.com says the shipping weight is 170 pounds.
Feb 01, 2010 | RCA F36450 36" TV
I need the part number for the control panel on my 36" RCA model number F36665.
p3001 is the number I have on wires,going from the motherboard to the control panel.It is A 36"RCA F36665 1999
Mar 29, 2009 | RCA F36665 36" TV
TV turns on and off by itself
  • Try replacing the batteries in your remote.
  • Cover the infra-red receptor in front of your TV to see if you’re getting unwanted signals from the receptor; covering the receptor with a bit of foil should do the trick.
  • Have you recently added equipment that might interfere with your TV’s operation—like a remote control extender or a new device for your audio-video system? Remove these devices and test the TV.
  • Feb 16, 2008 | RCA F36665 36" TV
    RCA F36665 36" red picture
    Do picture have little white lines in it? This could be caused by a bad CRT driver transistor. On the small CRT board on back of tube. The red could be shorted
    Dec 07, 2007 | RCA F36665 36" TV
    RCA Model f36665 Guide series 36" TV
    Who said it cannot be fixed? You can try and hook an external speaker to wires and test for sound. Maybe audio outs have sound?
    Oct 29, 2007 | RCA F36645 TV
    Rca direct view tv 36" f36665
    clicking,w/no sound or pix is usually IHVT, AKA flyback transformer.Please clarify size and model #. Include last three characters in Thomson products service #---Ex.=F36665-YX01.
    Oct 02, 2007 | RCA 32F531T 32" TV
    RCA has no sound
    well u have a problem in the audio circuits of the tv which includes the speaker itself. but most of the time the audio power output transistor or ic get easily damaged resulting a no sound tv. if u dont have any idea with regards to this, i suggest have it check with a qualified service technician. it will not cost u a lot for sure.
    Jan 17, 2007 | RCA F36665 36" TV
    TV will not turn on when power button is pushed.
    check the main fuse in the tv. test it with a multimeter, not visually. if its the thermistor that blew the fuse, it is very difficult to see the break in the wire. replace if blown. if unit blown fuse again withing a couple of weeks replace the thermistor in the degausing circuit. good luck.
    Jan 09, 2007 | RCA F36665 36" TV
    RCA F36665 36" TV Logo
    42 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
