Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
MY WD can't recognize by my pc but last week i use it but there no problem but when i plug it again today in my pc the book are not be read and theres no icon that can be seen in the HARD DISK DRIVERS BUT My book is install and the message in the device manger is "This device is working properly."
    Brigadier General:
  • 10,406 Answers
Device Manager only says that the disk is getting AC power, and that the "data" cable is connected, and that Windows has recognized the specific device-information (that it is a disk-drive, and that the capacity of the disk-drive has been recognized).
Device Manager does not say that the "spinning" part of the disk-drive is still spinning, nor that there are any I/O errors (trying writing with a pen onto greased paper -- not everything you write can be read).
Try connecting the MyBook to a different USB port on your computer.
Try connecting the MyBook to a different computer.
If it still is not "readable", then you have a few options:
* if the warranty still is valid, exercise the warranty, to get it repaired/replaced,
* disassemble the case, disconnect the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a "slave" drive in some desktop computer, to see if the USB-to-disk-drive adapter has failed
* buy a replacement disk-drive, connect it to that USB-to-disk-drive adapter, and close the case, to create a "new" external disk-drive.
Posted on Oct 24, 2010
SOURCE:
I have a WD 1.5 TB My book 3.0. I have it for a couple of weeks, but now all of the sudden the PC(s) doesn't recognize the device anymore. Device manager does display the right hardware, and says it...
Try this. Download a program called discovery from WD, it is free. When installed, plug in the drive and run the discovery program. Your drive should work properly. Please let me know how it works for you.
Sep 19, 2011 | Western Digital My Book Essential Edition...
PC and laptop will not recognize WD external drive. I have Window Premiun 7 new PC and noticed my pictures were being saved to My Pictures in PC. I do not want them saved there so unplugged WD then deleted...
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the USB. If you received a cable with a split dual USB plug for extra power make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 06, 2011 | Western Digital 500GB My Book World...
My book hard drive was hooked up to my new computer last thursday (64 bit Windows 7 professional) and worked great came to work today and computer will not recognize it no matter what I plug, unplug and...
This drive should work with Windows 7. Contact WD support and they can send you diagnostics to run.
You may try the drive in another computer, and try restarting the 7 system.
Feb 01, 2011 | Western Digital My Book Essential Edition...
My Book 500 GB
Same problem here. I did recover some files when I commected it to another PC!!
WD should get this sorted as lots of peoples data is being lost.
Please let us know of a solution if you can?
Sep 21, 2008 | Western Digital My Book Essential Edition...
MyBook Failed - Not Sure I Want Their Replacement
I have 6 My Books I use for various types of data storage (2x 1Tb and 4x 500GB). I experienced problems with 2 of the 500GB drives over the last 3 months. Speaking with a tech at Best Buy, apparently the problems are common and are related to heat buildup inside the case.
I think the problem is not with the drive itself, but rather with the compartment (specifically with the USB or Firewire interface). The failures I experienced are intermittent: Windows does not recognize the drive and starts displaying an error about an "USB device not recognized". The first time this happened I let the drive sit and cool, and it worked again. I tested it for bad sectors and it came back healthy. Then after about a day of use, the same USB error hapepned and the drive became unreadable again. If you open the enclosure, remove the hard drive, buy a different enclosure in install it, I think it will work and you will get your data back!
Fortunately, I always do a back up a backup so I did not lose anything. Needless to say, however, after this kind of unreliable behavior, the drives are going out the door and I will replace them with a SCSI external disk enclosure. More expensive, but reliable. I will eventually ask WD to replace the bad ones, but I am not sure I will trust them.
As for NTFS vs FAT, you can re-initiliaze the drive with NTFS using DIsk Management without a problem. I did this to all of mine (usign WInXP Pro).
Mar 26, 2008 | Western Digital My Book Essential Edition...
My system no longer recognizes the MY BOOK (drive I)
check cables to drive, reboot computer a few times to see if it shows drive , last thing you could do is reformat drive, you may have lost the format.
Jan 15, 2008 | Western Digital My Book Essential Edition...
WD My Book Essential -- Can't find drivers
It should not really need drivers in Win2K or Vista, you might have a problem with your USB drivers. Go into device manager, remove any devices under the USB heading and reboot. All the drivers should reinstall and hopefully your MyBook will come alive again. Otherwise, try the MyBook on a friend's computer, if it doesn't work there then the MyBook may be faulty itself.
WD - My Book Won't shut off with computer, and now can't locate
Try unplugging Hard Drive, then a reboot of your pc and when the pc comes back plug it and then Power it ON. Hope this Helps Mutahir
Feb 03, 2007 | Western Digital My Book (WDG1U2500)...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
256 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
