Question about Acer Aspire One PC Notebook
I have a new aspire one d260 that will not connect to my network. it will not even accept that my router is broadcasting however it will pick up other networks on the street. I have even tried to connect manually by entering my ssid and gatekey. it still says that my network is out of range. this is not the case as i have another laptop connected
Can u see the wireless icon in the taskbar near the time?if not, try 2 right click my computer, then manage, device manager, and see under network adapter the wireless adapter, maybe it doesn't exist or is not recognized, or maybe it has a yellow mark with a question mark in it, if its the case, then you'll need to find and install the driver, all these assuming that your new aspire is wireless capable
Posted on Oct 24, 2010
SOURCE:
G'day Govinda123 We've bought a new Acer Aspire one laptop. When we try to connect to the internet, it picks up our network with excellent connectivity, but when we type in the network security key to...
I just baught a new Acer Aspire 1551-4755 yesterday, I spent 4-5 hours on the phone with the router people and they did everything they could to help, but there is something wrong with the acer software and acer will not help unless you pay them $100 for support.
Nov 01, 2010 | Computers & Internet
Latitude X1 PC Notebook: I just used ny Dell Latitude X1 to add a new lapto...
If the other laptop can't see the network, then it sounds like you somehow turned off SSID broadcasting while you were in the router's settings. Log back into your router and look for the SSID broadcast enable setting. Make sure it is set to on, then save the changes and reset the router if you have to. The laptop should be able to see it now. (There is also a setting in the Windows wireless network properties that you can check to connect to a network even if it is not broadcasting, as long as you have connected to it previously.)
Hope that helps!
May 17, 2010 | Dell Latitude X1 Notebook
My Netgear router is properly attached. It's supposedly working ok but no wireless is detected. Network Magic doesn't even recognize that it's there.
You may have the network as hidden. Try typing in the wireless name you gave the router and the password to see if it connects. It is possible that you have the router as hidden. If that does not work for you, you can go back into the administrative options of the router and reconfigure to broadcast publicly without and security enabled and see if you can pick it up then.
Dec 19, 2009 | NetGear WGR614 Wireless Router
Wireless not detected
Are you broadcasting your SSID 'Network ID" If not you won't see a wireless network if "SSID Broadcast" is turned off in the router.
Login to your router config page and enable 'Broadcast SSID"
Nov 22, 2009 | Acer Aspire 3000 Notebook
Laptop not picking up router that is connected tomy pc
Your wireless settings may have the SSID Broadcast switched off. If this is the case, your laptop will not 'see' the wireless network. You will need to manually add the wireless connection or turn the SSID Broadcast back on.
Sep 30, 2009 | NetGear Computers & Internet
How do i set a password?
Follow these rules for a secured WLAN
connect to your router as admin using Lan cable.
Set A router password. (if not already set)
Change your SSID from standard name
Consider do not broadcast SSID
In wireless setting select WPA-PSK security protocol
Create a Passphrase to be used as key (write it down)
save and use new setting in every connected device of this network.
I recommend first broadcast your network with WPA-PSK password.
Find your network with your clients (PC, Console, print server) use pw to connect in secured way.
Be sure to set client network properties to "connect to this network even if not broadcasting"
For increased security modify your network in Router to "No broadcast"
Jan 10, 2009 | Belkin Wireless-N Wireless Router with...
Wireless connection
What router brand/model do you have. Is it set up to broadcast it's SSID? Has encryption been enabled on the router?
Have you used Device Manager to make sure the new wireless card is operating properly.
I hope you'll answer these questions and let me try to help before you rate this...
Jan 03, 2008 | Belkin Desktop Card Network Adapter
WLAN connection
make sure that your wireless network card works.go to the settings of your router and set: wireless network mode:802.11b(or what your car supports) wireless network name:name Wireless SSID Broadcast:enabled Security Mode:wep wep key:write something create a new connection to your laptop with the above settings
Oct 04, 2007 | Computers & Internet
Wireless connection won't work at home
Check your router is accepting backward compatible connections of 802.11b, as it may be set at 802.11g only especially if it's a 108 or 125mbps router as your laptop will only be 54mpbs and not see the router at all. Sometimes you have to dissable then re enable the wireless network adapter or refresh it for it to do a new search of networks.
Jan 17, 2007 | Dell Latitude D620 Notebook
Acer Aspire One  PC Notebook Logo
125 people viewed this question
Ekse
Alun Cox
