Question about D-Link Computers & Internet
I cannot enter to the setup modem - D-Link Computers & Internet
I wanna protect my connection from outside users i dont know how to protect it !! please help me out!
You listed your problem ubder: modems. A modem you do not need to protect further. You can only use the connection by hooking up a cable to it. If you have a wireless router connected to your modem that should be secured. You do this by entering a security code in the setup of the router. just enter the router's IP address in your web browser, log in to it,go to the security tab under wireless setup and enter a security code. (write it down because you will need it to connect wireless). You can not connect to it without this code. This way your wireless connection is secured and can not be used by outsiders.
Feb 10, 2011 | Computers & Internet
Tip
BellSouth AT&T Motorola Modem Red Light/s, No Internet
Modem, Router and PC
1. Press and hold the reset button on the back of your modem for 10 seconds to fully reset your modem to initial factory defaults.
2. Wait for the modem's Power and DSL LEDs to turn solid green.
3. Open your computer's Internet browser and your modem should launch a mini-setup routine. Enter your FastAccess DSL username in the format of [email protected], enter your FastAccess DSL password and confirm your FastAccess DSL password and click next, then there will be an "Auto Calender Update Configuration" page where you will set the auto update info and timezone info so just enter the info and click next.
4. Your browser will refresh the page and say everything is ready to go, this may take a few moments. When this is complete type 192.168.1.254 into your browser's address bar and click on the "Broadband DSL Line" tab, then on the right, click on Connection configuration.
5. Change the Protocol from the dropdown box to Bridged Ethernet Mode, and then click on Save and Restart Connection.
6. Open your computer's Internet browser again and type in 192.168.1.1 into your browser’s address bar. In the Internet Setup, change the Internet Connection Type to PPPoE and enter your FastAccess DSL username in the format of [email protected], enter your FastAccess DSL password and click on Save Settings.
7. Close all windows and restart your computer. Your internet should now be working.
Modem and PC
on Jul 24, 2010 | Computers & Internet
Tip
How to setup the D-Link Dir-615 Wireless Router on the Internet 1. You will need...
1. You will need to connect your Cable or DSL modem to the Internet port on your router.
2. Connect your computer to any of the 4 LAN ports
3. Next you will want to insert the "Quick Router Setup Wizard CD" in to your CD-ROM drive. This will take you through the automated steps of setting up your router to work with your modem. Note if you have a DSL modem that uses a PPPoE connection software program you will want to uninstall it from the computer before you continue. Also you will need make sure you know the user name and password because you will need to enter it as a part of the setup for the router.
4. When the setup wizard opens you will want to click on "Install Router" in the upper left hand corner.
5. Click on the option for "Setup Wizard" to use the setup wizard.
6. Click "Launch Internet Connection Setup Wizard" to start to setup your LAN settings
7. Click "Next" to continue.
8. At this point you will be asked to create a new password. After you entered a new password click "Next".
Note it is important to setup a password at this point especially if you plan to setup a wireless network so no one will be able to gain access to your router settings.
9. Click on the drop down menu to select your time zone and click "Next"
10. You will need to select the type on Internet connection you have and click "Next"
11. Here are the different step you need to go through depending on the option you selected above.
DHCP
- If you selected DHCP then you might need to enter the MAC address of the computer that was last connected directly to your modem. If this is the computer you are currently connected to then just click on the "Clone Your PC's MAC Address and then click "Next"
Note you may need to enter a host name if this is required of your ISP.
PPPoE
- This is where you will need to enter your PPPoE user name and password.
Note as a reminder if you have not uninstalled the PPPoE software from your computer because it is not needed any more.
PPTP
- This is where you will need to enter your PPTP user name and password.
L2TP
- This is where you will need to enter your L2TP user name and password.
Static
- You will need to enter the network settings provided by your ISP
After entering the required information click "Next"
12. Click on "Connect" to save your settings. At this point your router should be rebooting. After it is done rebooting then click "Continue". Next you will need to wait 1 to 2 minutes while the router connects to the Internet.
Now you should be connected to the Internet. If you are not connected you may need to review you settings. Also you may try unplugging the power from your modem and the router. Then next plug the modem back in and let it run for about 30 second and then plug the router back in. If you still have trouble you may want to contact your ISP to make sure you have your settings right.
on Apr 26, 2010 | D-Link DIR-615 Wireless Router
Either my modem died, or just the input for the cable burned out on my Dell XPS 410. How do I replace them?
If the modem is integrated onto the motherboard, enter BIOS SETUP and "disable" the modem.
If the modem is an add-in card, remove it from the computer,
and purchase and install a new PCI-socket modem.
Nov 15, 2010 | Computers & Internet
I bought belkin g wireless modem ruter but they didn't give me CD . How can i install this and how can i use my wireless ruter please. Thank you.
Power-off your cable-modem (or DSL-modem).
Use an Ethernet cable to connect from the modem to the WAN port on your router.
Use another Ethernet cable to connect from one LAN port on your router to the network-port on your computer (desktop/laptop).
Turn the modem on.
Turn the router on.
Turn the computer on.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like:
Default Gateway . . . . . . . . . : 1234.678.0.1
Start Internet Explorer
Type http://1234.678.0.1
to access the web-server "inside" the router.
Run the Network Setup Wizard.
Run the Wireless Networking Setup Wizard,
to pick an SSID, an encryption-level (use 'WPA')
and to pick a network-password.
Now, you can disconnect the Ethernet cable from the computer, and try using the wireless-adapter inside your computer.
Sep 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to access your wifi password with 2wire homeportal 1000hw
If you have the setup menu login password you can view (and change) the wireless connection password in the modem setup menu. You'll need an ethernet cable to connect directly to the modem if you can't get to it wirelessly. With the ethernet cable you bypass the need for the wireless password but you will still need to get into the configuration menu, which usually has a password too. After you connect the ethernet cable, open a browser window and enter 192.168.1.1 in the address field and press enter. This is the same web address field you would use if you were typing www.google.com. That 192. address should take you to the modem setup menu. If a password is required it will prompt you to enter the password. If you don't know the password you'll have to reset the modem and start over. (yes, there is typically an actual reset button although many of them are hard to find) After a reset there is usually not a password requirement. Make sure you set all passwords again if you do a reset - want to be sure no one else can get into your router once you are finished.
Sep 19, 2010 | 2wire HomePortal 1000HW DSL Modem and...
Hello. I've setup a LAN of 2 computers, a router and a ADSL modem at home, but when I plug both computers to the DLink 524 router, all the lights become less bright and I can't connect to the router, even...
reset set the modem first. then connect the one system to adsl modem. type 192.168.1.1 in browser. enter user name&password.go to interface setup tab-internet--select bridge mode--save and reboot. now remove that take router connect to system type 192.168.1.1 in browser. enter user name&password.go to interface setup or advance setup in that wan tab or internet tab select dynamic ip and lan page give different network address eg-10.0.0.1 for router 10.0.0.2-...254,255.0.0.0,10.0.0.1 save and reboot it will work or just call 08041478653 , 9740575949
Feb 25, 2010 | D-Link AirPlus DI-524 Wireless Router
I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 31, 2009 | Actiontec (GT701) Modem
Connection problem
check for static ip or dhcp setup on cable modem if static you will have to enter in speadstream if dhcp dynamic ppoe enter isp
Dec 21, 2008 | Efficient Networks SpeedStream 2108...
Wireless Modems
If you have DSL service, Actiontec makes a wireless DSL modem thats easy to setup. It had a built in router in it.
You should setup wireless security for your network so that you won't have any unauthorized inturders entering your network.
Jul 28, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Open Questions:
Computers & Internet Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
