Question about Nokia e65 Cellular Phone
How to activate the pocket data - Nokia e65 Cellular Phone
    President:
  • Nokia Master
  • 1,932 Answers
To subscribe to packet data you need to contact your service provider through phone or go directly to their office.
They will send you the settings for your model. Please save the settings to your phone and set it has a default settings. Then you can start using the internet in your phone.
Thank You
Posted on Oct 24, 2010
2 Suggested Answers
SOURCE:
rajat2392
  • 136 Answers
SOURCE: sir how cant i activate my pocket data for
in settings menu, goto configuration settings, and then to acess point
Posted on Mar 15, 2010
What to do if data network cannot be activated even if smartphone is internet and mms capable?
Try the configuration that's usually provided by your network provider.
Dec 05, 2012 | Samsung Galaxy Pocket
How to subscribe packet data
try contacting network provider for activating Subscribing pocket data
May 04, 2011 | Cell Phones
Sir how cant i activate my pocket data for
Mar 14, 2010 | Nokia 6300 Cellular Phone
How do I enter data through my PC to my iPAQ 2210
You have to check the synchronization settings. Select " Keep data on my pc" rather "keep data on my devce " fo rthat matter.
Sep 10, 2009 | HP iPAQ H1940 Pocket PC
Nokia3110classic pocket data
you have to activate the gprs connection first and have to enable the settings for that.contact the network service provider
Sep 10, 2009 | Nokia 3110 Cellular Phone
How to install themes
Here is your Pocket PC's default theme
wm6_default.jpg 1. Connect your Pocket PC to your Desktop using your cradle and Microsoft Active Sync, Once it is Connected double click on the green circle on your taskbar to open the Active Sync Window (If the Circle is grey, then it means that your Pocket PC is not properly connected).
2. Now you need to click on the explore Icon.
3. Here you can see the files and folders on your Pocket PC. Navigate to the “My Documents” folder. (This is where we suggest that you put your themes) . You can also use the“Windows” folder or Main directory of a storage card (not in a sub directory).
4.Now you need to drag the TSK theme files that you have chosen from your desktop computer to your pocket pc 5.Now you need to activate the theme file on your Pocket PC:
Tap Start, Settings, Today, Select your chosen theme, and tap OK.
Your new theme will now be activated.
You can download the themes from: http://www.htcfreeware.com/HTC/categories/HTC-Themes.aspx
Jul 14, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Does anyone kno how to put music n a pda2k pocket pc???
yes dear its so simple just use ur pocket PC data cable with your PC and install Active sync on ur PC and get connected ur PDA with it an icon of MY MOBILE shown in ur explore form where u can do any thing u wanted with ur Pocket PC like add music vedio and software of any kind...if need more help..reply me back..Take care
Mar 04, 2009 | i-mate PDA2k Pocket PC
I can't connect my HTC P3450 with my laptop.
active sync is for using transfer your data like contact,calender,task and....just like back up your phone data to your computer,but you must have microsoft outlook on your computer.
and it also can let you install pocket pc software from your computer to your pocke pc.
Dec 27, 2008 | HTC Touch P3450 Smartphone
I mate JAM POCKET PC PROBLEM
YOU CAN DOWNLOAD THE SOFTWARE FROM THE MICROSOFT WEBSITE CALLED ACTIVE SYCORINATION FOR POCKET PC
Jul 11, 2007 | i-mate JAM Pocket PC
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
Nokia e65 Cellular Phone Logo
89 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
