Question about AudioBahn A4002T Car Audio Amplifier
Audiobahn A4002T that keeps popping fuses
I have an audiobahn A4002T that keeps popping number 40 fuses and i cant figure out why. Its wired up with an 8 guage wiring kit.
  • 631 Answers
Does it blow them immediately when inserted, only after the headf unit is turned on or only at high volume?
Posted on Jun 08, 2008
  • javuot27 Apr 15, 2011
    it blown off immediately!
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
My amp and stereo keep shutting on and off.
It would make sense that if your radio turns off, your amp will shut off too since its likely your amps remoae power signal is delivered via the light-blue wire from your radio.
so the question is, why is your radio shutting off.
Odds are your using an aftermarket radio and your ground wire is poorly connected.
check it.
May 03, 2011 | AudioBahn A4002T Car Audio Amplifier
I have two audiobahn aw1500 15" subowoofers and i was trying to figure out how to wire them so that they come to 2 ohms. I have a Kicker 400.1 amp that is 2 ohm stable.
What is their ohms at the moment. If they are 8 ohms the will become 4o hms in parallel, 4 ohms will become 2 ohms in parallel. Since your audiobahns are dual four ohms coils one speaker wired in parallel gives you 2 ohms and both wired together in parallel will give you 1 ohms. You will need to wire them in series parallel to to keep two ohms and that is a waste of power. Kickers are good amps, with a little extra cooling the amp should sustain the 1 ohm capability of your parallel connection or trade in for a 1ohm stable amp
Apr 02, 2011 | AudioBahn AW1500 Car Subwoofer
I have a audiobahn a4002t. it will not power off when the key is off and removed. i have even tried disconnecting the remote wire and this does not help. i have tested the radio for functionality of the...
More than likely the amps internal relay that is powered by the remote lead has shorted open, allowing the amp to connect power and ground regardless of the remote signal.
Should be a relatively inexpensive fix at an electronics repair shop.
Jan 03, 2011 | AudioBahn A4002T Car Audio Amplifier
My protection Light came on. How do I get it to go off?
audiobahn went out of busnes 5-8 years ago i wold replace the amp with a class d diferant brand
Jun 17, 2010 | AudioBahn A4002T Car Audio Amplifier
Audiobahn a8002t schematic
audiobahn.com under tech support you can download your manual for almost any thing even shows you wiring diagrams helped me out...
Mar 01, 2010 | AudioBahn A8002T Car Audio Amplifier
AUDIOBAHN A2601X AMP FOR CAR KEEPS BLOWING A FUSE
its probably something lose inside ur amp that causing the amp to ground out ur fuses every time
Feb 22, 2010 | Car Audio & Video
Audiobahn a4002t beats steady and alternates between power and protect mode. need help.
That usually happens when your amp keeps clipping and basically doesn't have enough juice to push the speakers. You can try to ground the amp better, preferably to the chassis, and you can also get a capacitor and see if that helps keep the steady power going to it. There are those times that the amp is just getting old, but I would try these simple solutions first. Hope this helps.
Dec 31, 2009 | AudioBahn A4002T Car Audio Amplifier
Remote bass control short
It Could be Eiher Problem Make Sure The Remote our using is thew same brand as the amp its plugged in to
May 27, 2009 | AudioBahn A4002T Car Audio Amplifier
Audiobahn A2300-HCT
bring it to a hifi or tv repairstore
Nov 04, 2006 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A4002T Car Audio Amplifier Logo
217 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
