Question about HP Deskjet D4260 Printer
Arrow and tear drop shaped lights on front of printer are flashing and printer will not print ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
SOURCE:
My printer is giving me error code 5b02 i have tried replacing ink absorber but its still giving same, i have tried to reset but it showing offline printer please help me
Under Set Destination, click the drop down arrow (JPN) in front of Region: and select USA - click Set (you get "The function is fished!)
Under Clear Ink Counter, click the drop down arrow (Main) in front of Absorber: and select Main-Black - click Set (The printer prints one sheet)
Under Ink Absorber Counter, click the drop down arrow (Main) in front of Absorber: and select Main-Black - click Set (The printer prints one sheet another sheet)
Click EEPROM and the printer prints one sheet
Click Auto on the top right of the Service Tool Window
Click Test Print - wait until all is done. Restart the printer and you should be good to print again
For Support Call Our Toll Free 1 888 224 4280
Aug 02, 2018 | Computers & Internet
Tip
I followed the steps outlined by nanicool to remove jammed paper from an...
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 24, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Teardrop shaped light flashing on hp 5650
Hello Sgaetjens,
The tear drop shape LED is called the print catridge LED indicator. If you do see this light flashing it means that there is an issue with one or both of the cartridges. This issue can occur for the following reasons:
  • One or both cartridges might be incompatible with the product.
  • One or both cartridges might be improperly inserted.
  • The borderless printing settings require adjustments.
For the first,two I suggest that you verify that it is indeed HP original cartridge and not just replacement ones that you can purchase anywhere. Remove and reseat the ink cartridges carefully. With regards to borderless printing, go to Control Panel and then Printers and open up your HP Printer and then check the properties and defaults. Normally it is under Printing Shortcuts where you could find Borderless Printing.
Jul 22, 2011 | HP DeskJet 5650 InkJet Printer
My printer does not want to print. it has a flashing red light on one of the three buttons underneath the on/off button. it is flashing red underneath the little tear drop sign (that's the best way i can...
If the red light keeps flashing and you can print, then it means your color cartridge has no more ink in it. Please replace it. If this is not the case, switch off the printer for few minutes (10mins), unplug the power cord and reinstall all the cartridges.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 19, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
WHAT DOES THE TOP TEAR DROP SHAPED BUTTON MEAN WHEN IT IS FLASHING ON A HP DESKJET 3820
The flashing teardrop light indicates your ink is about out.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | HP DeskJet 3820 InkJet Printer
Not printing documents and flashing light in tear drop shape
Try changing the cartridge and checking if the problem continues
keep me posted
cheers
Nov 13, 2008 | HP Office Equipment & Supplies
Paper light flashes red...
I found just doing this one simple thing sorted the problem.
First take off the front cover. Pull the tabs on the side. Pull out the big toner and cartridge. Do you see the blue tab on the top shaped like an arrow/triangle? Slide the tab from right to left - reinsert toner close door.
Hope it works for you
JPW
Aug 30, 2008 | Brother HL-2030 Laser Printer
Printer not working
Red light near tear icon is indicating no ink, when you press ink button carriage should move to center of printer, if you open lid and look where it stops there is a arrow pointing to which ink need replacing, replace ink indicated with gen epson cart.
Oct 29, 2007 | Epson Stylus C86 InkJet Printer
HP Deskjet D4260 Printer Logo
449 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
