Question about Proscan PS27500 27" TV
No Sound My TV has no sound through for anything that is run through the cable connection but has sound for any device that goes through the analoge input. Any suggestions as to what the problem is? Thank you
Have you had your ears checked?
Posted on Sep 24, 2008
Why can't I get picture or sound when my Sound Bar, TV and Blu-ray player are connected?
You have to run an audio cable from the TV to the sounder and put the sounder on the TV input for sound to work. The first choice audio cable for best sound would be optical cable if your tv has optical output on it. If it does then you would put the sounder on the din input for sound when watching antenna or any hdmi source connected directly to tv. If your TV only as analog rca out or mini audio out then put sounder on aux input. I think your sounder came with mini to mini stereo cable. If your TV doesn't have mini audio out the get a optical cable or you can find a mini to rca red/white will work. Optical is your BEST connection and soundbar would stay on din all the time for best sound.
Feb 10, 2015 | Vizio S5430W-C2 54-Inch 3.0 Soundbar Black
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.
1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting.
2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer.
Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Oct 27, 2012 | Sharp AQUOS Quattron 60 Class LED 1080p...
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
Jan 20, 2011 | JVC HD-61G787 61" Television
Trying to add Wii, but no video only sound.
The manual says you can get an optional Component Video cable (RVL-011) for the Wii. There is apparently one unused Component Input on theDenon where you could connect it. You would still have to use the Red/White analog audio.
The Yellow is for Composite Video only. It's lower quality and not compatible with Component Video (3-wire).
In the short term, why don't you just run the Wii's combined Composite video / analog audio cable to the provided Composite Inputs labeled DVD, VDP, TV/DBS, VCR-1 or VCR-2 on the Denon?
It would not be necessary to have BOTH Composite and Component video from any device, much less the Wii.
Ponder this, why do you need to run the video from anything to the Denon at all if your TV has mutliple video inputs? TV's specialize in video, theDenon specializes in audio. You can always extend the Red/White audio cables to reach the Denon.
May 06, 2010 | Denon AVR-2802
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
I just bought the 52 inch philips lcd tv model number 52pfl3603d. I'm trying to hook it up to my philips surround sound model hts3544 so I can hear the tv thru the surround sound. Watching a dvd is no...
Is the volume on the dish network device turned all of the way dowm?
Is the dish network connected to its pwn input on the SS system and did you turn the SS system to that input ?
Are you using the analog input (red and white) cables to the input from the TV to the SS System?, not from the SS box? This is not the correct setup?
Sep 25, 2008 | Philips Audio Players & Recorders
Digital audio out jack
That output only works with digital signals (digital tv channels and digital audio from the hdmi in jack).
The HDLCD2600 has no analog out. Sorry.
Aug 14, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Nov 29, 2007 | Onkyo TX-SR605 Receiver
Proscan PS27500 27" TV Logo
53 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
