Question about Philips 42PF9630A 42 in. Plasma Television
Unclear picture Replaced projection lamp picture is not clear. It appears to have a haze in the background.
  • Anonymous Jun 10, 2008
    i was watching my 42inch tv and all of a sudden the picture went bad and i have vertical lines and the background is fuzzy
  • 138 Answers
Vertical line if in the menu also will need a panel if no need an small signal board.
Posted on Aug 19, 2008
Mottled background
Sounds like you may need a new lamp according to my Samsung DLP manual for a HLR4667W.
"Why do I need to replace the lamp?
The lamp used in a DLP TV has a limited lifespan. For the best screen quality it needs to be
replaced periodically. After replacing the lamp, the screen quality will be bright and clear as new."
Nov 12, 2013 | Samsung HLP4663W 46" Rear Projection HDTV
I REPLACED THE PROJECTOR LAMP ON MY TV . THE PICTURE IS SHARP AND BRIGHT BUT THERE IS A BLUE HAZE IN THE BACKGROUND . iTS MOST NOTICABLE WHEN THE PICTURE ON THE SCREEN IS LOW LIGHT. ARE THERE ANY...
When you replaced the lamp, was it doing the same thing? I doubt the lamp was bad, maybe but doubtful. I would try to adjust the color on it. What kind of TV do you have? I need the model and year.
Jan 24, 2011 | Televison & Video
White haze and very unclear picture. Seems the
Search for "coolant change projection tv", there are several good links including where to buy the coolant. I did mine yesterday and it's like having a new TV again, all for about $20 and 3 hours time.
Nov 11, 2009 | Philips 43PP9202 43" Rear Projection...
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Computers & Internet
White haze on projection
If your TV is a philips magnavox its most likely the CRT fluid is cloudy and should be replaced.
Got to www.TvRepairKits.com for a kit + instructions.
Jun 20, 2009 | Televison & Video
Blue haze on tv picture
I had the same problem with mine..it was the circuit board. Good thing I had warranty. It was over $800
Mar 28, 2009 | Hitachi 51F59 51" HDTV Projection...
I changed the LCD lamp, but there is still a yellow haze.
The yellow haze is the result of the blue polarizer burnt-in, you will find it sitting in front of the dlp chip.
Mar 20, 2009 | Zenith E44W46LCD 44" Rear Projection...
TV background in green and most of the people have green tint
http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
Dec 17, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
WD-62525 works fine but has hazy picture!
ISCABITTLE-TRY REMOVIG THE WHOLE FRONT SCREEN ASS'Y. AND CLEANING THE SMALL MIRROR INSIDE/BOTTOM YOU'LL SEE A HUGE DIFFERENCE-JOE TV
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Philips 42PF9630A 42 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
