I've connected to my "THOMSON TG585 v7" by telnet but I can't configure it's SNMP and I have an answer that I don't have a permission.
4 Suggested Answers
SOURCE:
  • 77 Answers
SOURCE: Open NAT with Thomson (Speedtouch) TG585 v7 Router
First, try adding a wireless card to the Xbox, run the wireless off of the router OR if you have multiple connections (broadband, should be an "In" port, and several "Out" ports) Try connecting your PC and you Xbox through the "Out" ports, with the cable modem cord hooked into the "In" port...
Posted on Feb 04, 2009
SOURCE: Wireless modem-Thomson TG585 v7 Slow download
i want to change internet access password
Posted on Jun 26, 2009
SOURCE: how to change IP of Thomson TG585 V7
yes you can change it !!! check this speed touch site: http://www.speedtouch.net.nz/500ChangeIPaddress_v4.3.htm
Posted on Aug 25, 2010
How to connect new devices to Thomson router (TG585 v7)
Using a command prompt and telnet:
Type in telnet 192.168.1.254 and hit Enter. If this doesn't work, then you don't have Telnet installed and will need to go to Start ? Control Panel ? Programs ? Programs and Features ? Turn Windows Features on or off ? Ensure TELNET CLIENT is checked and click OK.
When prompted, the default username is Administrator (case sensitive) and the default password is either blank or the serial number of the router (case sensitive):Click to open image
Type in "connection unbind application=SIP(TCP) port=5060" (without the quotation marks) and press Enter. If you get a 'unknown command' message returned once you press enter, then type in: "connection unbind application=SIP port=5060" (without the quotation marks)
Type in "saveall" and press Enter to apply and make this setting permanent
Feb 27, 2017 | Computers & Internet
I need to change the wireless channel on my Thomson TG585 V7 and I have no idea how to do this! HELP I'm a complete novice. It is because my DSi is having problems communicating with the router. I have...
If this window does not appear browse to http://dsldevice.lan or the IP address of your Thomson Gateway (by default: http://192.168.1.254 and click Thomson Gateway on the menu on the left-hand side.
Change the wireless channel
Proceed as follows:
1 Browse to the Thomson Gateway Web Interface.
2 On the left menu, click Home Network.
3 Under Wireless, click your access point.
4 The Wireless Access Point page appears.
5 In the Location bar, click Configure.
6 Under Configuration, select the channel of your choice in the Channel Selection list.
7 Click Apply.
Helps that helps!
Jan 15, 2010 | Computers & Internet
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
Thomson TG585 v7 Resets When Rebooted
once agian reset it then put in proper place you get it or do one thing press reset button after removing the power twice time then put on the power then re-cofigure it sir/madam
Mar 03, 2009 | Computers & Internet
Feb 02, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Thomson router TG585
do u do any frimware update for you thomson if you do u have to complete it
Jan 19, 2009 | Computers & Internet
Thomson TG585 v7 malfunction
just one answer frimware filure did you skip or try to frimware you self with lan cable
Jan 17, 2009 | Thomson 29DM400 29" TV
Cannot reset to factory defaults Thomson TG585
You need press the reset button at least 15 seconds
Dec 25, 2008 | Computers & Internet
Speedtouch 585V6, mapping ports doesn't seem to work properly. I need port 343 mapped for my work vpn, done it on other brands of router but this one is getting the better of me, as it disconnects from...
connect to webmanagement via internet explorer http://192.168.1.254
Click on Toolbox
then Game & Application Sharing
Click on Configure at the top
Use UPnP or Create custome port.
I have a THOMSON TG585 v7 or may not be the same.
Hope this helps.
Jun 08, 2008 | Computers & Internet
Open Questions:
Aol verizon support phone number +{1-855*536*5666*} -Aol verizon Customer Service- XXUNKWM Aol verizon is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Aol verizon email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Aol verizon support number When you are using the Aol verizon for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Aol verizon support number and ask for the help. Once you dial the Aol verizon customer support number, you come in contact with a team of experts at the Aol verizon customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Aol verizon support phone number will help you with that simply and quickly. This is Aol verizon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Aol verizon agent. Features of Aol verizon support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Aol verizon customer support phone number. Here are some of the features of customer service: The Aol verizon customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Aol verizon customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Aol verizon provides you the facility of Aol verizon support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Aol verizon. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Aol verizon Customer support number team.
Oct 18, 2019 | HIS Computers & Internet
Computers & Internet Logo
555 people viewed this question
Ekse
Alun Cox
