Question about Philips HTS3357/05 Theater System
Hi there! I was using my hts3357 for 2 years with no problem. Now i have one: when i insert DVD/CD, it can list the files (divx) in it, but doesn't play. On the other hand, when i copy the "same" movies to a flash disk the player can play them well . I'm thinking of using a lens cleaner but if the problem is the DVD reader in it, why it can list the files? That's confusing. Is there any fix to watch movies from DVD/CD again? Thanks in advance!
  • hakanmk Oct 25, 2010
    Reneeturner7,
    Thank u very much for quick response and detailed explanations! i'll try fix it the way you tell.
    New Friend:
  • 3 Answers
I would try a disc cleaner and using a can of compressed air. be careful not to let the device receive any of the actual propellant by using small bursts of air. otherwise if u hold the nozzle down to long u could do damage to the device other than good. sometimes the eye is strong enough or not dirty enough to read just the file portion but not good enough to read the movie portion. It can read the Usb part due to the reader using the microchip part in the player not the eye of the dvd player. A usb port and a optical drive work entirely independant. usually if it won't read it means it is either the eye dirty or the eye is not working anymore. independant electronic / tv repair shops can replace the eye for approx. $50.00. But if the cleaner doesn't help letting the player read the movies again. Then I would suggest taking it to a shop and having the eye replaced or just do a "tune up" on it.
Posted on Oct 25, 2010
    Thanks a lot for your help but cleaning the lens did not fix it :( I think i will find a repair man to get the eye replaced or try to find another solution.
SOURCE:
What file formats does the Sony DVP-NS51P support?
It will play the following: DVD Video VCD SVCD DVD-R DVD-RW DVD+R DVD+RW CD (Audio) CD-R CD-RW Picture CD DVD+R DL DVD-VR as well as MP3 and JPEG file formats. Hope this helps.
Jan 10, 2011 | Sony DVP-NS51P DVD Player
How can I burn a CD with a movie file to use on a DVD player?
First of all do you have the right kkind of dvd player?
I have a dvd player that plays DIVX movies, so I use Roxio software and burn a data cd of an avi. file. From my understanding AVI, DIVX, & MP4 can be read as a divx. Make sure you close you secission on the disc or it wont play.
Sep 19, 2009 | Panasonic DVD-S77 DVD PLAYER
Does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
Apr 08, 2009 | Philips DCP851 Portable DVD Player
DVD DOESNOT PLAY REAL PLAYER VIDEO
This model cannot play real player video files your model work on DVD, CD, and on the following compressed file formats:
Compression formats - MPEG1 , MPEG2 , DivX 3.11 , DivX 4.x , DivX 5.x , DivX 6.0
Your player can play only mpeg , avi , and divx, not real player .rm files. I don't think there are many DVD that can play real player files around.
Dec 22, 2008 | Philips DVP5140 DVD Player
DivX certified player cannot read DivX files on DVD+R
Is there a Divx logo on the player? Does this particular DVD player capable of reading DVD+R disks?
If you used the Divx converter program, there is a way to create a DVD in Divx format with menus. Did you use that particular program? If you didn't, you may have the DVD in a data format and the player can't read it that way.
Dec 10, 2008 | Sony DVP-NS67P DVD Player
Playing DivX
Try burning a different DivX file to another CD or DVD to see if it is a problem with the disc you have.
Aug 07, 2008 | Philips DVP3140
Nero 7 burning used for pictures/video
There are many was to burn photo or dvd using nero.
The only thing you need to know is what format your dvd player accepts. If it accepts jpeg or kodack then you can burn staright to the cd.
If your dvd player hase Divx the tiy can burn any media to cd using Divx player. If not then you need to convert the file to dvd format.
Using Nero to make a dvd.
1. click on Nero and select DVD on the top middle and then click on the tab Photo & DVD
2. Then click on MAKE YOUR OWN DVD
this will open a new window here you need to select from the right hand side ADD VIDEO FILES.
3. Once loaded click next and let Nero recode the video format to dvd.
4. Insert a new dvd and burn it
This is the only way to recode a normal video file to dvd format.
Hope it works for you as its worked for me many times in the past.
Good Luck!!
Jul 07, 2008 | Ahead Software Computers & Internet
Prblem with samsung dvd hr-737
Hi, I have the same problem. Have called Samsung, those **** don't know ****. The player also doesn't recognize DIVX. This is what you get when you buy Korean cheap ****. I've sent mine in the garbage. I was smiling as the garbage collectors came and took it to hell.
Mar 16, 2008 | Televison & Video
How i can view divx whit subtitles (.srt, .sub.ssa)?
Look for firmware upgrades in Samsung's website.
You have to download a set of files, burn them on to a CD or DVD (check the help file in the download) and then insert the CD or DVD to your DVD Player and follow the on-screen instructions. It is really simple, just make sure you download the correct upgrade from the website. And one advice, use a RW DVD or RW CD because you may have to try it many times ;) .
Nov 10, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Philips HTS3357/05 Theater System Logo
427 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
