Question about BenQ FP72E 17" LCD Monitor
Power led turns on but there is no dispaly - BenQ FP72E 17" LCD Monitor
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL/BenQ (BenQ made a lot of DELL monitors)monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Oct 24, 2010
2 Suggested Answers
SOURCE:
  • 13 Answers
SOURCE: my lcd model # 1901FP when power on dispaly on
Hi, This is a common problem with LCD monitors and is usually a result of blown capacitors or it could be a failed backlight as the inverter will shut down if it detects this. You will need to open up your monitor and you will be able to see if any capacitors have "blown" but failure of a lot of components will cause this symptom.
Posted on Oct 14, 2009
Testimonial: "my lcd model # 1901FP when power on dispaly on after 2sec diplay off at this time power led show green .again power on /off button off and on the same (power on dispaly on after 2sec diplay off at this time power led ) plz find solution asghar"
How do I fix no video on a LG 55lm6200?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 19, 2015 | LG 55LM6200 55 1080p 120Hz 3D WiFi LED...
Power on/off problem when i monitor power bottom on work properly next i monitor power off .again power bottom on then the power led blecking and no dispaly
switch could be bad. Just leave the monitor ON. When you shut down computer the monitor will just go to SLEEP.
Apr 05, 2014 | Computers & Internet
TV LG MODEL : 42PJ350R-TA
scren no dispaly power , per led red sty in on
why this problem
May 01, 2013 | Televison & Video
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
There is 3 phase power to the inverter. Motor is ok. There is no dispaly and power led is off on front panel. no short circuit in motor or inverter ( combivert f5)
If there is no LED or display the inverter is not being powered up. Most likely a defective power stage which would need to be repaired.
Nov 15, 2010 | Inverter KEB COMBIVERT F5
HP E800 PAVILLION WILL NOT POWER ON
If there is not LED glowing in from of the servers, check the power cable is seated in properly. If that is also fine, the problem is with the power module itself. Get it replaced.
If there is LED dispaly and no BIOS screen coming up, Switch off the server and make sure the memory modules are seated properly in DIMM slots.and also the processor and HDD.
If still it didnt come up, better contact the vendor.
Please come back and vote for me if this turns to be helpful for you or also if you need more clarifications. Thnx
Mar 27, 2010 | HP NetServer E800
My lcd model # 1901FP when power on dispaly on after 2sec diplay off at this time power led show green .again power on /off button off and on the same (power on dispaly on after 2sec diplay off at this...
Oct 14, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Model: hp dv5-1002au os: windows vista. processor: AMD Turion. capslock and numlock led blinking constantly.
shut down ur laptop, check any key stuck in the keypad? if not, just clean ur keypad, and switch it on then check, if not then remove the battery, ground the battery terminal in laptop start laptop without the battery, then let me know ok? :-)
Aug 24, 2009 | HP Pavilion dv5-1002us Laptop PC
Aman
You can try a Hard Reset.
Unplug Power Cord. Let the unit stay off for 5 minutes. Then plug the cord back in and check.
Also check if you get any kind of beep sound or flashing led on the dispaly.
Refix the video cables as well.
Let us know what happens.
Regards.
Mar 24, 2009 | Sony KP-51WS520 51" Rear Projection...
BenQ FP72E 17" LCD Monitor Logo
171 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
