Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
18" Husqvarna chain saw purchased from lowes in 2009. Cranks fine when cold. After running for some time, and the saw is warm, if it is cut off, I can't seem to get it to crank again. If it cools back down, it will crank fine. any help would be appreciated. Replace plug last fall with one of the "really good" type plugs that Lowe's sells. Using the synthetic oil that is good for all mixtures/ratio's.
    New Friend:
Check to see if your saw is still under warranty, if it is Husky should fix it. Otherwise- when the saw is cold, pull the plug out and ground it on the cylinder head somewhere and pull it through. (Make sure the on switch is in the ON position) You should see spark. Run the saw until it gets warm and dies, as you say it does. Then re check the spark as when it was cold. If it doesn't have spark then you probably have a short in the coil/ignition system caused by heat. You will have to replace the coil/spark plug wire assembly. Since the saw is new, there is a good chance this is the problem.
Posted on Nov 08, 2010
SOURCE:
What causes the Clutch drum gear that drive the chain to go bad ? my chain eats a groove all the way through it aftr about 12 hrs of cutting I have replaced it 3 times now.
The chain you should be using should be a .325 pitch and not a 3/8.
Never over tighten the chain, it will wear and stretch with time, which is why you should regularly check the chain tension. To get it right you should be able to lift 2 drive links clear of the bar. The chain will naturally wear groves into the spur sprocket, there is no conversion to a rim spricket for this model. Rim sprockets allow the chain to move along the sprocket easier and takes the wear away form the clutch drum.
Oct 11, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
My husqvarna chain saw will start fine and run good and cut good for a few minutes then it will start running fast then slow down run fast slow down it will do that 3 or 4 times then cut off any idea...
It certainly sounds fuel related, remove the fuel hose from the fuel tank and replace the filter on the end, try the machine again, if it is no better it could well be an issue with the fuel tank breather, to test this run the saw until the problem starts to occur, slacken the fuel cap enough to allow air into the tank, if the machine picks up and runs well you will need to replace the tank breather, let us know if this works and i will will go through how to change the breather.
Feb 09, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have the same problem with my 350 Husqvarna chain saw. I took the saw to a licensed Husqvarna Dealer. The dealer said that there was noting wrong with the saw. The dealer did clean the carb. I brought...
The temperature is not that different. Is there a fair change in altitude between the dealer and where you live? The jet screws have 'D' heads to prevent owner tampering--how did you adjust them? You need to allow the engine to warm up before pulling the throttle. Make sure the fuel mix is fresh and mixed 50:1 with synthetic chain saw oil--be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. It has to be the manufacturer's problem because it is under warranty. It sounds like the jet screws are set fairly lean. Ask the dealer if you can buy the special 'D' head screwdriver to make your own adjustments. Hope this helps!
Jan 09, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Hi, I go t a new Husqvarna 450. It cut fine for 10 mins and then stopped cutting well. Engine runs fine but it barely cuts at all. The cut is black as if burned and there's sparks from the chain on the...
Suspect that the chain hit a rock or pocket of dirt which will dull the chain in a heartbeat plus pull debris into the chain groove area. Remove the bar and chain and clean everything thoroughly including the chain and bar groove. Inspect the chain teeth carefully looking for burned teeth and other physical damage. If badly damaged, suggest replacing the chain. It's not likely that the bar sliding surfaces have been severely damaged. When you have everything back together and the chain adjusted, start the saw and run the bar tip near some cardboard--it should throw off a thin line of oil in a few moments. There should be an oil volume adjustment screw on the back or just under the same area near the chain return. Turn the screw CCW to increase flow. Hope this helps!
Jul 13, 2010 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 359: Has run fine for 3 years. Now when first starting idles fine but as soon as it warms up idle speed increases enough to continually engage the clutch. Carb. setting have never been changed...
I think an air leak and she is running lean. Maybe time for some pressure/vacuum testing. Continuing to tweak the carburetor may camouflage a larger problem until the saw fails.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 05, 2010 | Husqvarna Chain Saw 20" Bar
Can't restart my new husqvarna 450 chain saw after a little bit of time using it. i followed the instruction manual both times.
The manual may not be clear, read warm line 3 below, read it again. The 450 manual I read says something similar under warm start. Are you opening the choke after turning on the ignition? Before pulling the starter rope? Flooding is the most common hard start problem with 2-cycle engines. If you are opening the choke I recommend you contact Husqvarna for guidance. They will likely send you to a neighborhood dealer, gratis.
HusqvarnaUSA.com/ContactUs
http://www.husqvarna.com/us/homeowner/support/customer-support/
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
Lou
Feb 28, 2010 | Husqvarna 450 e-series 18" Chain Saw
Craftman,36cc, 18" Gas Power Saw Blade
Go to a home improvement store and buy a new chain, they are cheap!
Jul 29, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Feb 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 345 power loss and vibrates
Replace the bar. Your bar has gone bad and that is why you are losing power. Bars are made by the chain saws to be completely oiled at all times. When the bar does not get oil the bar will start to warp and that is what will cause you lack of power when trying to due a top cut
Feb 14, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
137 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
lnbn1975
Marvin
Marvin
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
