Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Soap Dispencer Doesn't Always Open
More than half the time the soap dispenser will not have opened at the end of the wash. I've tried Cascade crystal soap and packets. Any suggestions?
  • Anonymous Jun 19, 2008
    Hi, I found the same problem and it always seemed to happen when I placed the taller items in front of it. Now, I place the smaller salad plates or bowls infront of that corner and have never had the same problem. Pay attention to whether what you place in front of it is blocking it or not. Good luck
We had the same problem and solved it by putting taller utensils to the extreme right of the basket or in the top shelf
Posted on Jun 29, 2008
We are having the same issue with a new dishwasher. One solution is to leave the soap dispenser box open when you close the door. This will at least get soap in the washer.
Posted on Jun 15, 2008
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
How do you clean the door gasket? It has black stuff on it.
once a month bleach machine out and clean out soap and softner dispenser,so lets start cleaning you are going to need a powerful-pool shock and put 1/4 of the bag in the soap area,you well need to let it soak for 24hrs. cause you have mold in every inch of the machine.Now run the machine on cold water.After machine has gone through all cycles.Open door you may need to clean door seal with a old tooth brush,and you may need to lift seal to check underneath.after seals are clean and dispencer is cleaned were dispencer goes make sure its clean as well. after use always keep door open and dry out dispencer after each use.always use a 1/4 of a cup of clorox2 for HE. and clean machine out this should stop ths problem.
Jun 17, 2010 | GE Energy Star WCVH6260F Front Load Washer
Dishwasher won't access soap tray
Check if the dish rack is reversed. If it is, it'll block the dispenser from opening.
If that is not the case - you may have problems with soap dispencer solenoid or with control board. Unplug the d/w. Disassemble the door, and find the solenoid contacts on the dispenser. Check for continuity. No continuity - replace dispenser.If dispenser is ok, check wiring for continuity. Otherwise it's the board.
Jun 01, 2010 | Dishwashers
Dishwasher - soap dispenser won't open while washing dishes
A simple was motor is used to open that.
This video shows how to change a door latch but the dispencer basically does the same thing. HERE
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Soap dispenser won't open
make and model are critical there are so many different types of dispensers that it is impossible to help you without this info
Apr 24, 2008 | Dishwashers
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Problems with fabric softener
check the water solenoid for open circuit, this is the water valve that supplies water to the compartment
Sep 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
274 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
