Harman Kardon HK 610 only playing out of one speaker
Hi! Anyone know anything about this amplifier.  Mine has decided to only play out of one speaker on all channels except the CD channel and I've swapped the speakers over already, it's definately not them.  Could it be dust inside?  Will I kill it dead if I even attempt to open it up and have a look?  I don't really want to throw it away and places that I've rung to fix it just tell me to get a new one. I'd appreciate your thoughts. Kelly
  • 54 Answers
Then only use the cd input for your output you may have to swap input wires from different sources as your tv audio output or tape output or tuner otput then just leave on cd and enjoy.
GOOD LUCK
BIGRED
Posted on Jun 21, 2008
Hi. We have a Harman Kardon DVD and AVR and a Proline TV. When playing DVDs the sound from the AVR is not playing all tracks (usually the voice track is missing) - just background music and the odd door...
Your HK DVD probably has outputs for left and right audio and video (possibly color coded red, white, and yellow). These should connect to the corresponding DVD (or VCR) inputs on the rear of your AVR. When you play a DVD with your AVR set for DVD/VCR input, you should hear all of the stereo audio (there are no "missing tracks"). Next, review your speaker connections. They should be connected + terminal to the corresponding + terminal on the AVR, etc. One or more speakers may be connected backwards. If your AVR has speaker system A B provisions, be sure that speaker (system) A only has been selected.
Dec 23, 2013 | Harman Kardon AVR 225 Receiver
Power lights not amp
Output problem, transistors shot
Nov 10, 2013 | Harman Kardon Harman HK 990 Amplifier
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Harman kardon 990 error
Hi i dont know if you found your solution but you can solve this on your own.
on the front there is two buttons you have to press and hold in standby mode. The "Level settings"button and the "speaker 1" button. when you do that you reset the firmware.
Nov 30, 2012 | Harman Kardon Harman HK 990 Amplifier
Connecting 4 ohm speakers
I don't think it has anything to do with the impedance. The amp and speakers are well in the allowed limits. The only time this is a problem is if you connect an amp with a greater impedance then the speakers.
This sounds like something to do with the HK 990. It could have a fault on it. You could try listening with headphones if the HK 990 has a socket for them. If they have low sound, there's an electrical fault in the power amp of the HK 990.
Jun 09, 2012 | Harman Kardon Harman HK 990 Amplifier
How are you? For HK990,How to do bi-wiring connection of the speakers? thanks
Sabve your money - it's BUY-wiring.
http://www.harmankardon.com/EN-US/Products/Pages/ProductDetails.aspx?PID=HK+990
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/HK%20990_OM.pdf
Bi-wiring does nothing but make you use twice as much speaker wire for the same electrical effect. Bi-amping assumes there are deficiencies in your electronics that must be worked around, again by using more speaker wire and separate amps.
Do some reading on the web about "bi-wiring".
Jul 16, 2011 | Harman Kardon Harman HK 990 Amplifier
It runs so hot why?
Possibly lack of ventilation or excessive volume through difficult speaker loads.
http://media.onecall.com/Image_Products/Harman%20Kardon/harman-kardon-hk990.pdf
See page 6.
IMPORTANT: When connecting two pairs of speakers, determine the impedance of each pair
by looking on the back of the speakers, in your owner's manual, or by contacting your dealer or manufacturer.
You can listen to two pairs of speakers at the same time ONLY if the impedance of EACH speaker is NOT LESS THAN 8 Ohms.
WARNING: Do not play sets of speakers simultaneously except as recommended above.
Amplifier may overheat.
Jul 09, 2011 | Harman Kardon Harman HK 990 Amplifier
Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 22, 2008 | Harman Kardon Go + Play Portable Speaker...
HK206 SPEAKERS WITH USB PLUG
have you plugged anything else in to make sure the usb port is working? does the computer recognize the usb speakers when you plug the usb plug into the computer? do the speakers work on another computer? if you wiggle the usb wires around does it make a sound through the speakers? eliminate these questions so that we can move on to isolating the issue.
Oct 13, 2007 | Harman Kardon HK206 Computer Speakers
575 people viewed this question
 Grubhead
Grubhead
