Question about Epson Stylus C46 InkJet Printer
Epson c46 keeps pulling paper through on angle
    New Friend:
Try using Epson paper, more expenive but less wasted paper
Posted on Nov 19, 2012
  • Epson Master
  • 7,733 Answers
Go to this LINK.
Posted on Oct 24, 2010
SOURCE:
Epson stylus c46 printer not working - not taking in paper
Reintal removes another program and see and remove the cartridge and put it another go and check that the paper has not stuck where you spend the role
Reintal in another program and see confguralo
Here you can find the driver you are looking for if you do not have the dvd
dell.com oh superarchivos.com
Oct 17, 2010 | Epson Stylus C46 InkJet Printer
Have flashing lights from Green to Red with no
Sounds like a maintenace pad problem (every Epson printer has a different set of flashing lights to indicate this "Maintenacne request"- read this link: http://www.epson.com/cgi bin/Store/support/InkPadsForm.jsp
Jun 01, 2010 | Epson Stylus C46 InkJet Printer
The epson c46 printer cartridge doesnt move for printing
It may have become jammed, open the cover and see if anything is jamming it such as paper.
See if with the power off it will move to either side with a little pressure.
The c46 is a cheap disposable printer, and may have just got to the end of its life
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 08, 2009 | Epson Stylus C46 InkJet Printer
My Epson C46 does not feed paper in correctly when printing
double check the rollers and feeders. There could be debris blocking it.
Nov 03, 2009 | Epson Stylus C46 InkJet Printer
Epson c45
I have problem with my epson R230 printer
I use CIS ink it works ok
but NO image appear on paper
what can I do for solve this problem ?
and why this problem appear ?
Oct 30, 2008 | Epson Stylus C46 InkJet Printer
Epson c46
Here is the link :
Epson Stylus C46 : Drivers & Software
Unplug printer USB before starting driver installation.
Note : Vista drivers are not available for this printer.
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
Check USB cable.
Try different cable and connect it to different usb port.
If it is not the cable, do the following driver reinstall:
Disconnect printer from usb
Remove printer from 'installed printers' in Windows.
Install again driver from disk with printer not connected.
connect printer when required by setup procedure or after installing drivers.
If it still does not wark then the printer is faulty.
Jul 11, 2008 | Epson Stylus C46 InkJet Printer
Old epson stylus c46
Just download the driver from epson.com.
Jan 17, 2008 | Epson Stylus C46 InkJet Printer
Help
could part of the paper still be in the unit look close, also when you pulled the paper out did you hear any of the gears move?
Dec 08, 2007 | Epson Stylus C46 InkJet Printer
C46 Epson printer
Check to make sure the paper alignment tool is up against the papers edge (snug), and verify no foreign objects in the feeder.
Nov 12, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
