Question about Asus Eee 701Sd Notebook
Cannot connect to wireless router at home...always pending!
  • ASUS Master
  • 7,733 Answers
Router model?
Posted on Oct 24, 2010
SOURCE:
My asus eee 900 won't connect to my wireless router in my home keeps saying pending what do I do? Help!!
Try it go tho control panel and see if this is coonfigurated well if this is ok change the wirless adaptor buy id does not exist try instal drivers again yes work
Feb 06, 2014 | Computers & Internet
Vista wireless connection to belkin-n
It sounds like your linksys is your main connection so therefor it will not always let belkin connect because your pc has registerd your linksys to be your connection.
Sep 20, 2009 | Belkin (F5D5231-4) Router
Asus eee pc 900a wireless connection not working
I've experienced the same problem with my ASUS netbook. Uninstall the wireless hard - remove hardware in control panel, reboot the machine and allow it to auto find the adapter again. This should correct it. If there are still problems verify that you have the most current driver for the wireless adapter, either from Asus, or the wireless adapter chipset manufacturer (i.e. Intel, broadcomm, etc.)
Sep 01, 2009 | ASUS Eee 4G Notebook
Will not connect to wireless networks. When I try, it just says connection is 'pending'
1: Choose "Network" in the Internet option, disconnect it and then delete the Connection in the "Manage".
2: Click "Create" to recreate the connection, choose "Local Area Network- Wireless", then Next.
3: Choose "Next".
4: Select Address Type, and then Next.
5: Browse Wireless Networks and then choose the one you want to use, you should see your wireless router/modem and the signal should show "Excellent" or "Very Strong". Choose the mode to be "infrastructure" and the Transfer rate to be "auto", and then Next.
6: Wireless Channel Settings, choose any channel.
7: If your AP is using the WEP or WPA encryption, you need to choose "Enable encryption" and then input the Key and Key index, (If you want your connection secured, you should use WPA and select a key index.) choose Next.
8: Fill in the Name of connection, then choose Next.
9: You can choose the "Connect automatically at system startup" or "Start this connection when finished" if you want, and then choose Finish.
This should correct your connection issues. Good Luck
Apr 13, 2009 | ASUS Eee PC 1000 Notebook
I have a D Link WBR 2310 router. I had it set up for wireless network on my home laptop. It was always configured for immediate access (no pwd required), secured with wpa. I try to connect with my work...
did you reset to factory defaults or just unplug the router?  If you hit the reset button, you'll have to go in and set everything back up.   Have you tried to connect via webbrowser connected to the router from your home computer?  go to 192.168.0.1 and see if you can connect to the router to see what's going on.
Dec 17, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
UNABLE TO OPEN ANY PAGE
You may want to check the wireless security settings ie. (WEP / WPA /WPA2...etc) on the router, certain settings don't always work well with the macintosh, try changing them and that should help your problem.
Nov 14, 2008 | Apple iMac G5 Desktop
Help me please
Two separate solutions are needed.
First, you will need to ask your ISP (Internet Service Provider) to assign a "fixed IP address" to your Internet connection. Your ISP typically assigns addresses to home users out of a large "pool" of addresses that are shared among several customers. Because of this, your home network address is not always the same. Most ISP's charge an extra fee to always keep your address the same.
The second task is to configure the firewall function in your router so it will pass connections through from the WAN to the device inside your network. The procedure to do this should be included in the instruction manual for your router.
Jan 06, 2008 | MSI Wireless-G RG54G3 Router
Open Questions:
See all Asus Eee 701Sd Notebook Questions
Asus Eee 701Sd Notebook Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
