Question about Health & Beauty
Can i test to see if a key switch is good on a power scooter
  • 280 Answers
The easiest test to see if you have a bad key switch is to bypass the switch. If the scooter works when you bypass (short across) the switch then you have a bad key switch. The hard part of accomplishing this is to take apart the console and housing of the key switch. Without knowing your model the basic answer is to look at the console housing and look for the screws holding the 2 halves of it together. Remove these screws noting where they go so you can reassemble the console. Once you have the switch exposed on the backside of it you can locate the 2 wires going into the switch. Find the part of these 2 wires which is bare (no insulation) either at the nearest connector or at the switch. Using a paper clip short across these 2 wires, i.e. use the paper clip to connect these 2 points together. If your scooter now works you have a bad key switch.
Posted on Oct 25, 2010
6ya staff
SOURCE:
ANY IDEAS WHY OUR CPI GTR 50 SCOOTER HAS NO POWER?
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a "LOAD" test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter control circuit, relay, or solenoid faulty.
11. Main fuse or circuit breaker may be blown or faulty.
12. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
CPI GTR 50 HELP
Chinese Scooter Club View topic No DC Voltage to the CDI
Scooter Troubleshooting Scooter won start All about Scooters
http://www.49ccscoot.com/manuals/CPI_GTR50_Service_Manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 02, 2016 | 2005 Cpi GTR 50
I broke my key off in my ignition on my Tao Tao 50cc scooter how can I start it until I get a new key switch ignition
Hi, Anonymous I would take the switch to a locksmith he can remove the key for a beer for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Hotwire the ignition switch
TaoTao Scorter Starting switch work around
How to hotwire Chinese Scooter
TaoTao 50cc Scooter Owners Manual
Mar 21, 2016 | Motorcycles
My scooter no power when I tern the key on new battery still no power
check inline fuse and recheck battery new doesnt mean free from defects if good check safety switch and key switch
Aug 15, 2015 | Health & Beauty
My amigo scooter will not turn on
need more info like model number, serial number have you tested the batteries and the key switch
May 02, 2014 | Amigo Health & Beauty
A key broke off in the ignition of our handicap motorized scooter
This is a common issue with the travel scooters. It is usually an easy fix without having to replace the key-switch.
You need the following tools:
Good eyesight and / or good glasses to see down inside the key switch. A strong, thin needle. A jewelers flat screwdriver or eyeglass screwdriver.
The broken key inside the switch will have a flat back and a toothed topped. The toothed side moves a series of spring loaded pins inside the lock.
With the switch turned to the off position...
Place the jewelers screwdriver down inside the switch where the key's teeth are, pushing back the spring pins, and getting leverage under one of the teeth to lift the key out.
The needle is used to release friction and back pressure off the key back against the switch housing.
Work it carefully and be patient.
Once the key piece is out try ebay for a replacement if needed.
A common key number for Pride scooters is the A126
Oct 28, 2013 | Electric Mobility Health & Beauty
Gogo elitescooter lights indicate battery fully charged but scooter will not go
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
Dec 26, 2011 | Electric Mobility Mobility Electric Power...
Have a power scooter with no key to start the power. chair
an electric scooter company can fit a new barrel for around $ 40
Oct 14, 2010 | Electric Health & Beauty
The keyhole to my electric mobility scooter wont work so i pulled it apart and i need to know how to re-wire it without a key, thankyou.
Hi. Most scooters only have two wires to the key lock. All the key does is supply power to the controller, 1 to 2 amps at most. It does not supply the full current to the motors, so only a light duty switch is needed. An automotive toggle switch would do the job. Remember that you will have no security, unless you have a second switch hidden somewhere else on your machine.Good luck. Neil.
May 25, 2010 | Health & Beauty
Scooter`s electric starter does not work
the neutral switch might be defective or the wire.
could be a bad key switch. try jiggling around with the key as you are pressing the starter button
Jul 22, 2009 | 2008 Tomos Se 125 F
Scooter stalls
Hi, the wiring must loose around the key switch, it might be a case of taking the tiller off and resoldering the wires onto the key switch. It not a major repair , just a case of getting the tiller panel apart and locating the wires to the switch.
Regards
GeWiz.
Sep 18, 2008 | Golden Technologies Companion II Travel...
Health & Beauty Logo
227 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
