Question about Home
Exploded diagram of how to disassemble the Grohe Kiwa P1X 3636/18 shower head for cleaning.
SOURCE:
  • 3600 Answers
SOURCE: Grohe Rainshower head arm
yes you can unscrew it counter clcok wise, be sure to put a rag on the output tube so you don't scratch it.
Posted on Aug 26, 2009
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
  • 172 Answers
SOURCE: Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Posted on Jan 21, 2010
  • 32 Answers
SOURCE: how to clean a grohe freehander shower head?
soak in white vinager
Posted on Dec 11, 2010
  • 9 Answers
SOURCE: Water pressure is decreasing from
Most of the time there is a little screen in the line or in the head itself try to find it and make sure it is not obstructed.
Posted on Jan 05, 2011
Does the Grohe Rainshower Classic 160mm hand shower headset disassemble?
my guess is a whole new shower head . they do not make to be repaired . but you might try soaking in CLR cleaner solution for a day or overnight
Feb 15, 2015 | Grohe Home
My grohe 5 spray plus hand held shower is locked in the hand held position and I can't get the top shower head to turn on. The control used to switch easily from top spray to hand held but is now locked...
The control may be clogged with mineral deposits and consequenly unable to function. You can try disassembling the shower to remove the deposits but it may be necessary to replace the complete unit.
Feb 13, 2014 | Grohe 28.444.AV0 Movario 5 Spray Hand...
How do i disassemble this shower head to clean out the mineral deposit?
Most often the shower head will be threaded together. Use 2 strap wrenches to take it apart. The strap wrenches will not damage the finish. Do not force it if the fixture does not come apart easily. Soak the head in vinegar overnight to loosen the mineral deposits and make it easier to work with. Good Luck
Jul 12, 2010 | Grohe 27.069.EN0 Relexa Ultra Shower Head...
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
The Grohe Movario shower head how do unscrew it to clean the head
On the face of the shower head where the water sprays out of ,their should be a threaded nut to unscrew This is called the aerator.This is the part wher the filter screen is .Once you clean this part you should be up and running.
Jan 25, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Home Logo
1,188 people viewed this question
Top Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
