Question about Karcher 2500 PSI Pressure Washer
Why dose my Karcher K2.35 keep blowing the gun hose off?
    Scholar:
  • 100 Answers
There is a good chance you are missing the black plastic clip that holds the hose into the trigger gun. If you look at where the hose goes into the gun there should be a flat slot where a black plastic clip would slide in and keep the hose into the trigger gun.
Posted on Oct 28, 2010
SOURCE:
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Karcher Leaking from Back or inside...Help please
Karcher pressure washers are very sensitive to over-winter freezing. The plastic parts break, and you have to replace all of the leaking parts.
You may be missing a locking tab, without seeing the thing apart next to the exploded parts view, it's really hard to tell. Search google for "karcher parts", and put in your model number...
Aug 03, 2015 | Karcher Garden
Water leaking out of bottom of washer
It sounds like water was left in the pump and i froze over the winter and cracked the pump housing. You can try taking the gun hose off and blow compressed air where the hose hooks on to blow waterwater out of the pump and dry the bottom. Then put some apoxy on the crack to seal it.
Mar 18, 2011 | Karcher 2500 PSI Pressure Washer
My karcher has a hole in hose close to unit can i cut it and put back in
if the hole is in the gun hose then no.
it will need to be replaced. try bunnings warehouse.
you may need to purchase the gun & hose together.
Dec 11, 2010 | Karcher PSI Electric Pressure Washer
Hose out of the karcher unit blows off
Sounds like you need a new hose if it keeps blowing off the unit, see attached link to purchase the hose.
http://www.wmpcs.com/index.php?main_page=product_info&cPath=81_55_58&products_id=286
Oct 29, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
Powerwasher hose to gun keeps blowing off when i pull the trigger of gun. the connection at the washer
Somewhere on the nozzle there is a lock. You must properly seat and lock the nozzle. Otherwise, guess what happens.
If you have done all this, I must surmise the lock is broken or has dirt in it.
Clean it real good - wash it out with water - and try again.
Hope this helps
a
Sep 21, 2009 | Karcher K2.26 Electric Power Washer
Trigger gun
It sounds like you left out the spring in the hose.
There are about 10 different models of K330 with several types of guns. Go here and search until you find the correct gun so you can see the diagram. I think it will be hard to buy a replacement spring, though.
Aug 03, 2009 | Karcher K2.26 Electric Power Washer
Where does small spring fit in gun of karcher pressure washer kb4040
Most Karcher guns I have worked on have had a spring behind valve between hose pipe inside gun.
Apr 21, 2009 | Garden
Can't get the spray gun onto the hose from the washer...no manual
Your posting is incomplete, so I'm not quite sure what we're dealing with here.  I understand the machine and the high-pressure hose are Karcher - right?  Is the gun also a Karcher part?  If all are Karcher parts, they should fit unless the screw threads have been damaged.  If they are not all Karcher parts, they will not fit because Karcher connectors are different from almost all others.
Please post again if this doesn't help, giving as much detail as possible, and I'll see what else I can offer.
Apr 04, 2009 | Karcher PSI Electric Pressure Washer
How do i connect the hose to the karcher k399 handle
Pop out the plastic tab at the base of your gun (use point of screwdriver/knife).
Then push the hose connection into the gun and push the plastic tab back into it's slot. This will hold the hose in place.
Jul 02, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
832 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
