Question about Singer 8280 Mechanical Sewing Machine
The thread is not locked and no stitch formation
    Genius:
  • 1,788 Answers
I know you do not want to hear it but your threading is not correct. Do this test, put the presser foot up, pull on the top thread it should pull smoothly,now put the presser foot down, pull the thread again and it should barely move. You have to make sure that the thread is getting the correct tension in the threading path and not tangled. Now check your bobbin threading, is the thread pulling smoothly? If, not see the way your bobbin is unwinding, do you have it in backwards? By the way, how is your needle, when is the last time you changed it? Do so now and make sure that it right size for your material and inserted right, flat side face the rear. Have you done any maintenance? Like oiling, cleaning out lint and such? Refer to your manual for oiling points. If, you do not have a manual go to www.singerco.com and download a free one and enlarge the diagrams to see everything really clear and save a copy. Singer have excellent customer service, and can be reached at 1-800-4singer.
Posted on Oct 24, 2010
SOURCE:
Tension settings for the elna lock t34d
all Sergers are usually set up so that the "normal" thread tension is 5 on all the dials, however you then adjust these slightly to achieve the stitch format you you want. Stitch length (dial on the side) is usually around 2.5. If your machine has differential feed, then start with this on zero.
Overlocks are different to sewing machines, the stitch forms differently depending on the fabric weight and where the blade is cutting so you usually do a little test on scraps and finesse by adjusting the looper thread tensions so the stitch forms evenly on both sides. If its tunnelling, ie pulling the fabric in, then release the two loopers or move the blade to the left to trim closer, or do a little of both.
Mar 18, 2017 | Elna Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
When "locking " a stitch, bottom thread breaks and/ or bunches up.
Make sure you hold thread in back of the lowered presser foot when you begin stitching, and that the needle is piercing the fabric so that the fabric isn't slipping down into the feed dogs (under needle plate area).Hope this helps you out,alexlefebvre.Jimmy
Apr 12, 2012 | Sewing Machines
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
Says check upper thread, but thread not broken. then stitches about 20 stitches and stops again
if it's losing power, you have a short in the machine.....if the stitches are jamming, you need to switch thread type. Many standard machines cannot function with the lightweight polyester threads ( especially the large spools made for sergers) so I recommend using coats and clark dual duty. ....make sure you have the same size thread on the top as you do on your bobbin....hope this helps
Feb 20, 2011 | Baby Lock Ellure
Sewing with heavy thread, what should the tension be set on?
hi there
the tension depends on thikness of material but you must use heavy thread on needle and thin thread on bobin case .
- you must be sew fiew stitches firist and look if losse stitch from down you must tight tension slowly sloly and if there is losse stitches from upper you must tight screw for bobin case spring slowly slowly until stitch format be agood condation.
best regards
ashraf abozid
[email protected]
Jan 06, 2011 | Juki DDL-8700
Factory settings for stitch length and width dials
I hope you have not left this machine for a year! (If you haven't used it, feel free to send it to me!) Since the tensions on this machine are automatically set with the automatic thread delivery system, check to see if you have stitch dial set for an overlock or a flatlock stitch (which is what you're getting now).
May 07, 2009 | Baby Lock Imagine
Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at [email protected]
Aug 10, 2008 | Baby Lock Eclipse Serger
Singer 8280 Mechanical Sewing Machine Logo
49 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
